Old 11-15-2015, 09:55 AM   #21
When I did the research for my upgrade I talked to the front axle manufacturers and was sent the specs for the different axles. The casting for the 10500 lb and the 120000 lb is the same. The brakes and everything else except he air bags were the same. So in case anyone was wondering this is a true 12000 lb axle.
Old 11-15-2015, 11:35 AM   #22
jmgllt's Avatar
Originally Posted by I-RV View Post
Also, the front axle is certified for GWAR of 12,000lbs. They actually label the axle. When going into Access Freightliner for my VIN, it specifies that it was modified.
Hank
Did also have this upgrade done?
jmgllt is offline   Reply With Quote
Old 11-16-2015, 08:55 PM   #23
Hello all, I'm new to the Forum and this is my initial post. I have been following this thread reference weight issues with the Brekshire, I have a 2011 FR Brekshire 390 RB 60, with tire size 255 80'S. My question is has FR issued a recall.
Paul
Paul
plewis53 is offline   Reply With Quote
Old 11-16-2015, 09:12 PM   #24
Campin Cajun's Avatar
Welcome to the forum Paul, I do not think FR has issued a recall on this issue.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 11-16-2015, 09:29 PM   #25
You would think that if they know there's a problem and apparently has recognized the problem they would issue a recall.
Paul
Old 11-16-2015, 10:25 PM   #26
accumack's Avatar
No recall. Get your unit weighed. front and back full fuel full propane empty water tanks nothing in the coach then email Randy with the weights if you are over on the front axle. It sometimes takes a while. I started the process back in June and just dropped my unit off today to have the upgrade done.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 11-17-2015, 12:29 AM   #27
I don't know the rules about recalls but I'm sure FR does. Don't worry about what it and get you rig weighed. How long have you owned the Moho? Have you never weighed it? The whole process goes very smoothly. Get it weighed and contact Randy. He is out of the office for a week or so.
Old 11-17-2015, 07:23 AM   #28
baddmann's Avatar
You have to get your coach weighed to see if it's affected. (Not all have the issue)
Empty your fresh/black/gray water tanks and fill up your fuel/propane. Once you do that use a CAT scale at any truck stop to get your weight. If you are overweight, (10,410 lbs on front, up to 2013) then email Randy to get the process started. If takes some time and effort (You have to schedule an appt and they prefer you go to Elkhart or Gaffney) but its worth it if you are overweight.
Most of the units that are affected are the 340RBs, but I have a 360BH and I was just a little over.
We are not retired, but we use our coach a lot. (16,000 miles in 18 months of ownership) We have been extremely happy with our purchase and will probably upgrade to the rear bath Berkshire XLT when/if they make it in March.
Brian and Kelly
2016 Entegra Anthem 44B
2013 Jeep Wrangler Sahara Unlimited
baddmann is offline   Reply With Quote
Old 11-17-2015, 07:24 AM   #29
I-RV's Avatar
Phil
Good info. about the front axle. Do you have any good info. about the rear axle? A couple years ago, I did an extensive research at AccessFreightliner, comparing the parts lists between my 340hp Berk and a 360hp Berk. I found no difference in the axle, shocks, air bags, brakes. Yet, FR specs. the 340hp's rear axle at 17,500lbs and that of the 360hp's at 19,000lbs.
I am speculating that FR does this because if one was to load up their 340hp with 19,000 on the rear and 10,400 on the front (the unmodified front axle), there would only be left 3,600 lbs for the toad - since GCWR is 33,000 lbs. With the modified front axle at 12,000lbs; fully loaded there would only be left 2,000 lbs for the toad.
It should be noted to others reading this, that originally both the 340hp and 360hp Berks had a 10,410 lb. front axle rating. Not sure when and if FR changed over to 12,000 lb. front axles and 275 tires on later models.
Over-loading the front axle is critical because it is the steer axle and it has been found that both the 340hp and 360hp need the 12,000 lb capability Especially models with tile floors; bunkhouse and rear bath models. The 12,000 upgrade to the 340 Berks is doubly necessitated, because it doesn't have much cargo carrying capacity in the first place and especially if you believe the rear axle to be 17,500 lbs maximum.
Besides the axles, the tires are another thing. The original Michelin XRV 255 tires have a combined maximum carrying capacity of 29,630 lbs. With the upgraded Michelin XZE2 275 tires, the maximum load is 35,050 lbs. No Berk would ever be that heavy, but it is a great comfort that there is a greater safety margin with the 275 tires. Also, since like I only run around 83 psi in the rear; the ride is much better.
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 11-17-2015, 07:31 AM   #30
baddmann's Avatar
Hank: Exactly. I was running 110/95 and now I can run 105/90. The ride is noticeably different. Much better.
FR switched the Berkshire from 10,500 front airbags and 255s to 12,000 front airbags and 275s in 2014. (I have the 2013 brochure and 2014 brochure and it lists the axle ratings and tires for each.)
Brian and Kelly
