Old 11-17-2015, 09:00 AM   #31
Thanks all, will have my coach weighed to see where I'm at. There's a lot of great information on this site, I really enjoy reading all the different post they are very informative. Thanks again.
Paul
Paul
plewis53 is offline   Reply With Quote
Old 11-17-2015, 09:12 AM   #32
gasman94's Avatar
Welcome to the forum, Paul.
Rich
gasman94 is offline   Reply With Quote
Old 11-17-2015, 12:23 PM   #33
I-RV's Avatar
Originally Posted by baddmann View Post
Hank: Exactly. I was running 110/95 and now I can run 105/90. The ride is noticeably different. Much better.
FR switched the Berkshire from 10,500 front airbags and 255s to 12,000 front airbags and 275s in 2014. (I have the 2013 brochure and 2014 brochure and it lists the axle ratings and tires for each.)
bbaddmann
If you think your ride is better, it can even be much better. You are running your fronts at 105 psi, but if you have the XZE2 tires, that pressure is good for 11,960 lbs, which I am sure your not carrying that. See the attached tire chart....
I suggest that you get a good idea of your actual axle weights and adjust the tire pressures to the chart for you particular tires with measuring when the tires are cool (in the morning before sun on them).
You might be able to get your front pressure down to 95-100 and rear to 95 psi. You will get the best ride, best safety and tire mileage if you match the pressure to the weigh. The pressure will change with the season temperature,
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 11-17-2015, 12:48 PM   #34
accumack's Avatar
Thanks for posting this. I pickup my upgraded Berk Thursday or Friday I can't wait.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 11-17-2015, 03:48 PM   #35
baddmann's Avatar
Hank,
They put XZA3+ tires on. I have the tire chart bookmarked so when I get a chance to reweigh I will make adjustments. The cold tire psi sticker above the driver's seat says 105/90, so I set it there.
(I had to take it to Freightliner because of a a/c fan issue.)
Brian and Kelly
2016 Entegra Anthem 44B
2013 Jeep Wrangler Sahara Unlimited
baddmann is offline   Reply With Quote
