Old 11-13-2015, 07:55 AM   #1
baddmann's Avatar
Just got back from Elkhart
Got the tires and airbags replaced on my Berk (explanation in earlier thread) and all I can say is WOW! The driving experience is completely different. Much more relaxed ride. Well worth the 12hr drive(one way) to Elkhart.
Special thanks to Randy for taking care of this. The experience was fantastic. (You created a Berkshire owner for life.)
Also, thanks to Craig for the factory tour. Very enlightening.
Saw the Berk XLTs getting built. They are very nice. If they decide to build a bath and 1/2 model, I will be spending some $$$ to upgrade!
Brian and Kelly
2016 Entegra Anthem 44B
2013 Jeep Wrangler Sahara Unlimited
baddmann is offline   Reply With Quote
Old 11-13-2015, 09:16 AM   #2
accumack's Avatar
I'm glad FR Berkshire is backing their product and doing the right thing.
I'm dropping my unit off Monday at a Freightliner dealer for my upgrade and some scheduled maintenance.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 11-13-2015, 10:30 AM   #3
AREA51's Avatar
You can't beat the team at the factory. We have never been disappointed.
GOOD LUCK
AREA51
AREA51 is offline   Reply With Quote
Old 11-13-2015, 06:00 PM   #4
mikeborny's Avatar
What are you having upgraded?
Mike & Amy + 3 and the dogs!
2014 berkshire 390bh-40
mikeborny is offline   Reply With Quote
Old 11-13-2015, 06:10 PM   #5
accumack's Avatar
Front airbags and tires. We were sold units over weight on the front axle. 2011 rb 40. Bath and a half 340 hp engine tile floors 10,400 max front axle 22.5x255 tires. We were overweight with full fuel, propane, empty coach empty fresh, gray, black tanks just wife and myself.
Ham KG5LTL.
Old 11-13-2015, 07:57 PM   #6
baddmann's Avatar
I have a 360 and the 360 has the same front axle.
Brian and Kelly
Old 11-13-2015, 08:43 PM   #7
accumack's Avatar
The 360 should have a 12,000 lbs front axle and the larger tires. I don't think the bunkhouse is affected. I have the rear bath and a half.
Ham KG5LTL.
Old 11-13-2015, 09:21 PM   #8
Not true. Up until 2014 all Berkshires came with 255 fires and 10400 lb steer axel. This includes the 340 and the 360 hp motor. You are correct in that the RB is most affected by over weight but there are a lot of BH that are over as well. The best thing to do is get your Moho weighed. Don't assume you are over weight or that you are good. Weigh the Moho.
Old 11-14-2015, 09:07 AM   #9
baddmann's Avatar
Exactly. I assumed for 16,000 miles that since I had the 360 AND a bunkhouse I was fine. So I had the coach weighed and I was over. Just take the time to weigh. If anything, it will help you know how much air pressure you need in your tires.
Brian and Kelly
Old 11-14-2015, 12:18 PM   #10
Is it not great to read something POSITIVE for FR!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jim in Halifax is offline   Reply With Quote
