Had a great time. Coach ran well towing the trailer.
The only thing that stopped working was the night shade. I did all the programming and it still won't move had to roll it up by hand and use bungee cords to secure it for the drive home. Question. Does any one know if the night shade and day shade use the same fuse? I'm guessing they do.
I think they do. Did you check to see if a wire came loose? I had that happen. I also had to replace a motor on mine. It was working fine and just quit. It acted like yours. Like no power. It's not to bad a job to replace the motor. You can find them on line or from Andy at FR if that's it.
TaterColo: Look at the upper right corner of the shade and you should see two small wires with a little black push button switch hanging down. This is for programming the limits of travel for the shade. For some reason, it seems they occasionally forget the settings. When that happens, they only move a certain amount if none at all. Hold in the button until it beeps, then have someone try to raise or lower the shade. Not sure it will work but worth a try. Good luck.
