Old 04-16-2016, 09:07 PM   #31
Kenny kustom's Avatar
Originally Posted by dan-nickie View Post
Screw on fitting? What are you driving, bicycle? LOL
Nope.
Name:	ImageUploadedByForest River Forums1460858830.262105.jpg
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 04-16-2016, 09:11 PM   #32
dan-nickie's Avatar
Originally Posted by Kenny kustom View Post
Nope.
Attachment 105162
2016 Sabre 36QBOK
OIC, it's a fancy screw on fitting.
How is this connected to your coach air compressor?
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 04-16-2016, 10:07 PM   #33
Yup.
Like I said. It's a screw on fitting.
Confused ?
2016 Sabre 36QBOK
Old 04-17-2016, 02:28 PM   #34
dan-nickie's Avatar
Yup.
Confused ?
2016 Sabre 36QBOK
Yes, confused. Where do you get the fancy screw on thing (link). The only screw on valve's I have seen before work on bicycle pumps. This one looks very nice.
And how do you connect it to your coach's air compressor?
Seemed like a great solution. Can you help me get it all set-up? Much appreciated
Dan
Old 04-17-2016, 03:31 PM   #35
Dan, it comes with the VIAIR set up. It has a male air chuck fitting on the end.
Paul
2015 XL 40QL-60
2015 Jeep Wrangler Unltd. Sahara
Paulie Boy is offline   Reply With Quote
Old 04-17-2016, 07:01 PM   #36
accumack's Avatar
I could never use something like that as the compressor low limit is below my required pressure so I would be there for months and never reach the correct pressure. My air has a low limit of about 90-95 psi and I run 105 psi in my tires. It would be a MAJOR P.I.T.A. for me! It may ok for a trailer but not a Motorhome.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 04-17-2016, 07:47 PM   #37
For factory service. NO you don't "have to go to a rally" to get service. In fact, at the rally they have so many people/units to service I am sure the techs would much rather have your unit at the factory where they can take a little bit more time on the repair. Your best rule of thumb on what the factory will and will not do is to hear it ONLY from the factory. That way you know you are getting the truth.
Good Luck,
Karen[/QUOTE]
I'm going to take photos of our step cover repair job that the dealer's service department did and send them to the factory. Will be speaking with them. We don't mind paying for it as long as it looks like it's supposed to!
Glad to know what length of air hose to get too! That was going to be my next question.
The Mrs. is so psyched about driving the Berk. She also wants to practice driving my Exped. w/trailer. Told her sure, but only with it empty. Plus she's insisting on learning the MH hook-ups too. That teaching/learning curve ain't gonna last long.
Bud Ezekiel H. is offline   Reply With Quote
Old 04-17-2016, 08:48 PM   #38
My " trailer" tires are 110 psi......
This compressor is 150psi max.
Paul is correct. Comes with the 400p RV.
2016 Sabre 36QBOK
Old 04-18-2016, 07:27 AM   #39
Fulltime family RVer
My trailer tires are 125 psi and the Viair 450P does a great job airing them up. 12v, so it could be used on a motorhome or trailer.
I didn't get the same fitting as Kenny Kustom with mine, though. Just a clip on fitting. But it sounds like it may not have enough bite with extensions. I also carry a second dual head chuck like Dan mentioned that might work.
Seems like a few ways to skin a cat. If you have on-board air and it'll push air into a tire- there seems to be no need for an external air compressor (or there might- no idea, I don't have it). But the various attachments might be useful.
