Old 12-08-2014, 06:36 PM   #11
Ours came on it new. Just need our code now. Help me out if possible.
Sent from my The Foys iPhone using Forest River Forums
360PDEK is offline   Reply With Quote
Old 12-09-2014, 07:06 AM   #12
If you did not get the instructions, contact Bauer for one. There is a default code that will reset when ever you change the batteries. Then you can put in your own code. With our own code in you can the lock it by touching the bottom 2 pads.
We camp on earth with a Sun Seeker 2300
yworrydog is offline   Reply With Quote
Old 12-09-2014, 07:33 AM   #13
3 Happy Campers's Avatar
RV Lock
After using our keyless lock for three seasons it is still working great.
This past April I had to spritz the cylinder with a little lock lube because it was getting a little stiff.
I will have to say that it really eats batteries! It takes (4) AAs to operate.
I install new batteries in April & replace twice over the summer.
Thatís (12) AAs over eight months.
Now to be fair we are constantly in & out of the 5er & going off site so the lock gets a lot of use. Your mileage may vary
Dave, Judy & Daisy May
Perkasie, PA
2010 Sierra 356RL
2011 Silverado 2500 4WD, LT, Ext Cab, LB
Duramax 6.6L V8 Turbo Diesel
Allison 1000 6-Speed Automatic Transmission
3 Happy Campers is offline   Reply With Quote
Old 12-09-2014, 02:29 PM   #14
Just checked, the directions for changing the code on on the inside panel for the battery cover.
Old 12-10-2014, 09:28 AM   #15
Berkshire club
Berkshire Driver's Avatar
i got one of theses locks and the Bershire has a larger handle opening than that door handle so i returned it, but has anyone researched if a Charleston one can be made to work on our Berkshires? there is a dealer rep you have to contact to get a kit but wanted to take a close look at the assist bar lock before going any further, the lock does also connect to the storage bay doors and will lock them but sounds like a lot of hidden wiring for all of this modifications i am sure i could install one but would take quit a while to do.
2014 360QL-60 Mystic Garnet
Berkshire Driver is offline   Reply With Quote
Old 12-11-2014, 10:39 AM   #16
Back to the Berkshire keyless lock system. I have checked with the lock manufacture I think it's TriMark. They say they are working on it but thats the same answer I have gotten for two years. I had a guy in Elkhart that was going to install one for me but he couldn't find one that would work with our door. I asked at the factory and was told I would need to replace the door to get a keyless system. I don't understand why this is such a problem. I don't want to lock anything but the dead bolt. I know that the handle lock is complicated with the two stage lock so I understand that but a simple dead bolt should be easy to do. If anyone comes up with a fix for the Berkshire let us know.
Old 12-11-2014, 05:41 PM   #17
tmmar's Avatar
Phil,
That is what Lippert has been telling me- that they are working on it. I have been getting that answer for about 1 1/2 years. Don't know why our set up is so different from others that they don't have a keyless entry for our coaches.
I guess we will just need to wait and see if something becomes available.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 12-11-2014, 09:38 PM   #18
I believe it has to do with the DOT standards. The motor home entry door latch has to meet a higher level than that of the trailer door. This is because of passengers in the motor home while in motion vs the trailers not allowing passengers while in motion. I know that tri-mark had different door latches for out side compartment doors vs entry doors. Even though they looked the same. This was on ambulance and rescue trucks.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is offline   Reply With Quote
Old 12-11-2014, 09:53 PM   #19
Campin Cajun's Avatar
What's different on our Berks in comparison to Newmars and others that have the keyless locks?
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 12-12-2014, 11:18 AM   #20
The DOT stuff is in the two stage lock and not what you want to connect to a keyless. The keyless works on the dead bolt and should be a simple add on. The two stage lock is way to complicated for a keyless.
