Old 07-10-2014, 11:11 AM   #11
JTN8's Avatar
I see!! That would definitely bother me too! I would disconnect the water line to the faucet and get a bucket and check the pressure before it goes through the faucet if it's still low then it's not the faucet, if it's normal then I would look for a reducer in the faucet or just replace it with a residential one. Mine is completely different than yours both in style and pressure.
Jason
Old 07-10-2014, 12:02 PM   #12
Did you check for junk in the screen?
Old 07-10-2014, 12:27 PM   #13
Iwannacamp's Avatar
Originally Posted by klucas View Post
Attachment 57811
This is the flow on the kitchen faucet. Everything else is really good. It's always been much lower than the rest. I have traced the lines back as far as I can and haven't seen any reason for the low flow. I was just thinking it could be the faucet or a pressure reducer somewhere.
That silver part on the head should screw out... take apart... clean and install. You could check the flow without the diffuser.
Iwannacamp is online now   Reply With Quote
Old 07-10-2014, 03:41 PM   #14
klucas's Avatar
Yes I did. I took of the screen and check. When I had the hose of the handle that was low flow also. Maybe there is some junk in the internal works of the faucet or at the connection under cabinet. When I get home I will have to take it off and check it out. Thanks for the ideas.
klucas is offline   Reply With Quote
Old 07-10-2014, 03:46 PM   #15
B and B's Avatar
My kitchen facet in my TT had plastic shaving they made it through the system, it blocked the HW line, not quite that bad though. The suggestion of removing the inlet pipes and checking would be a good idea if you are able to do so.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 07-10-2014, 03:49 PM   #16
Ford Idaho's Avatar
I second this question, if the water faucet aerator screens are plugged with junk it can be cleared easy.
Old 07-10-2014, 03:50 PM   #17
ot06865's Avatar
I changed out the plastic faucet with a nice metal unit from Lowes. Had to get the adapters to match the RV inlets but Lowes had all the hardware too. No problems at all with the install but the flow would be based on the regulator that you use to supply the RV. I've opted for the High flow unit but it still limits what you can get out of it compared to the house.
Pam & Len K.
2012 Blue Ridge 3600RS
2012 Chevy 3500HD Silverado LTZ
Full Timers since June 2012..... and lovin it!!
ot06865 is offline   Reply With Quote
Old 07-10-2014, 03:53 PM   #18
tmmar's Avatar
Klucas,
Is your coach an '08? We had the same faucet in our '08 and had the same low water pressure. I removed the plastic disc in the faucet and didn't see any improvement. After seeing the water flow from yours, I should have replaced the faucet. The pressure from the faucet in my '14 coach is much better. I think the only solution is to replace the faucet.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 07-10-2014, 04:22 PM   #19
klucas's Avatar
Originally Posted by tmmar View Post
Klucas,
Tom
No ours is a 12. This has been a nagging problem but at the end of the list. Finally getting to this one. I will try to disconnect under the cabinet and see what the pressure is prior to the faucet. That should tell me if it is prior or the faucet itself.
Old 07-10-2014, 04:23 PM   #20
klucas's Avatar
I think I'm going to give that a try. Hope it helps increase the flow. Thanks.
