Old 07-10-2014, 09:33 AM   #1
klucas's Avatar
Kitchen sink.
Has anyone changed the kitchen sink to get better water flow?? Someone previous suggested there was a pressure reducer just before the faucet connection. I haven't been able to find that so I am thinking of changing the faucet with a new one from home depot or something. Anyone do this? If so did you get better water flow?
klucas is offline   Reply With Quote
Old 07-10-2014, 09:36 AM   #2
TURBS's Avatar
Theres a water. Saving flow restrictor in the outlet.
Old 07-10-2014, 10:02 AM   #3
klucas's Avatar
Would it be possible for you to take a picture of it. I would like to remove it. The only thing I see is where the hose connects to the faucet itself.
Old 07-10-2014, 10:09 AM   #4
nuisance's Avatar
we changed ours out after the handle broke, bought one at the hardware store with a bonus separate sprayer head. Changed out the bathroom faucet at the same time, didn't want the same thing happening during our 3 month trip last year. Very simple to do. DH did the kitchen as he had to drill the hole for the bonus sprayer and I did the bathroom change. I really like the extra sprayer head on a hose.
[COLOR="Red"]Al and Deb
Sugar and Anna Belle
2016 Toyota Tundra
2011 Greywolf 26rl
nuisance is offline   Reply With Quote
Old 07-10-2014, 10:10 AM   #5
TURBS's Avatar
Do you have a rigid outlet that swivels side to side or a pull out faucet head/ sprayer?
Assuming you have the pull out combo unscrew the hose from the base of the pull out sprayer head .
It should be there.
My unit is 90 miles away and wont see it till late friday evening.
Old 07-10-2014, 10:21 AM   #6
klucas's Avatar
It should be there.
Name:	ImageUploadedByForest River Forums1405005605.365144.jpg
The brass peice in the hose? If so how did you get it out? The handle side had a small valve. Looks like a back flow or something. I removed it and didn't see a difference.
Old 07-10-2014, 10:36 AM   #7
TURBS's Avatar
It would have been on handle end.
Old 07-10-2014, 10:40 AM   #8
klucas's Avatar
Ok. There was a small plastic valve. No change in water pressure. Any other ideas??
Old 07-10-2014, 10:50 AM   #9
JTN8's Avatar
Are you sure it's the faucet? My 2014 390BH's water pressure is perfect. Weather on city hook up or pump, all of my faucets have strong pressure. I would ensure the lines are all good.
Old 07-10-2014, 10:58 AM   #10
klucas's Avatar
Name:	ImageUploadedByForest River Forums1405007781.893086.jpg
This is the flow on the kitchen faucet. Everything else is really good. It's always been much lower than the rest. I have traced the lines back as far as I can and haven't seen any reason for the low flow. I was just thinking it could be the faucet or a pressure reducer somewhere.
Old 07-10-2014, 11:11 AM   #11
JTN8's Avatar
I see!! That would definitely bother me too! I would disconnect the water line to the faucet and get a bucket and check the pressure before it goes through the faucet if it's still low then it's not the faucet, if it's normal then I would look for a reducer in the faucet or just replace it with a residential one. Mine is completely different than yours both in style and pressure.
Jason
Old 07-10-2014, 12:02 PM   #12
Did you check for junk in the screen?
Old 07-10-2014, 12:27 PM   #13
Iwannacamp's Avatar
Originally Posted by klucas View Post
Attachment 57811
That silver part on the head should screw out... take apart... clean and install. You could check the flow without the diffuser.
Old 07-10-2014, 03:41 PM   #14
klucas's Avatar
Yes I did. I took of the screen and check. When I had the hose of the handle that was low flow also. Maybe there is some junk in the internal works of the faucet or at the connection under cabinet. When I get home I will have to take it off and check it out. Thanks for the ideas.
Old 07-10-2014, 03:46 PM   #15
B and B's Avatar
My kitchen facet in my TT had plastic shaving they made it through the system, it blocked the HW line, not quite that bad though. The suggestion of removing the inlet pipes and checking would be a good idea if you are able to do so.
Old 07-10-2014, 03:49 PM   #16
Ford Idaho's Avatar
I second this question, if the water faucet aerator screens are plugged with junk it can be cleared easy.
Old 07-10-2014, 03:50 PM   #17
ot06865's Avatar
I changed out the plastic faucet with a nice metal unit from Lowes. Had to get the adapters to match the RV inlets but Lowes had all the hardware too. No problems at all with the install but the flow would be based on the regulator that you use to supply the RV. I've opted for the High flow unit but it still limits what you can get out of it compared to the house.
Pam & Len K.
2012 Blue Ridge 3600RS
2012 Chevy 3500HD Silverado LTZ
Full Timers since June 2012..... and lovin it!!
ot06865 is offline   Reply With Quote
Old 07-10-2014, 03:53 PM   #18
tmmar's Avatar
Klucas,
Is your coach an '08? We had the same faucet in our '08 and had the same low water pressure. I removed the plastic disc in the faucet and didn't see any improvement. After seeing the water flow from yours, I should have replaced the faucet. The pressure from the faucet in my '14 coach is much better. I think the only solution is to replace the faucet.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 07-10-2014, 04:22 PM   #19
klucas's Avatar
Originally Posted by tmmar View Post
Klucas,
Tom
No ours is a 12. This has been a nagging problem but at the end of the list. Finally getting to this one. I will try to disconnect under the cabinet and see what the pressure is prior to the faucet. That should tell me if it is prior or the faucet itself.
Old 07-10-2014, 04:23 PM   #20
klucas's Avatar
I think I'm going to give that a try. Hope it helps increase the flow. Thanks.
