Old 03-24-2016, 07:05 AM   #1
EJM4's Avatar
Kitchen Sink Discharge Hose
Has anyone ever replaced it?
During our trip to Florida this week, we found the hose has a crack.
Not sure if this is a job for me or the repair shop!
Earl
2013 Berkshire 390BH / 360hp
EJM4 is offline   Reply With Quote
Old 03-28-2016, 11:26 AM   #2
I'm an amateur plumber, and here's my approach to indoor projects: don't work on anything where the leak would run onto a lower floor, and don't work on something where my wife will need it to work that same evening (usually, when she's home, this is the kitchen sink and master bath)
So, the waste line for the sink is probably not putting anything but your basement storage items at risk, and, if you're not staying in the rig right now, I'd say try to fix it yourself. If you can't, you can call a professional, which is where you would be anyway if you don't try it alone.
Moose
2009 FR Berkshire 390BH
jbramhall is offline   Reply With Quote
Old 03-29-2016, 08:57 AM   #3
I read this and I'm sorry I have no idea what the discharge hose is.
Old 03-29-2016, 09:28 AM   #4
Are you talking about the stinky slinky or the s trap?
lefaivre is offline   Reply With Quote
Old 03-29-2016, 09:32 AM   #5
EJM4's Avatar
The flexible hose that comes off the trap from the kitchen sink.
Earl
Old 03-29-2016, 01:45 PM   #6
So it's the flex hose connecting the drain in a slide? That should be doable. I bet you will need to be limber.
Old 03-30-2016, 06:19 AM   #7
EJM4's Avatar
Correct.
I looked at it again and made an appt to have it repaired.
Earl
