Old 03-02-2014, 10:31 AM   #1
Leaks!!!!!
OK, so I sat thru about 12 hours of wind and rain yesterday (a severe weather event here in AZ, but don't worry we WILL rebuild) and had some water coming in just below the storage compartments above the driver/passenger seats.
There is an upholstered panel directly under those cabinets and that was where the water was coming out; no leakage within the compartments themselves, since there is a double "floor" in them. Water was coming in between the floor of the cabinets and the aforementioned panel.
That upholstered panel appears to be (at least partially) held up by some sort of fasteners (buttons that are also upholstered). To help clarify, that panel is where the defogger fans are mounted.
So, the question.... Has anyone had to remove that panel?? I'm totally dry this morning, but wouldn't mind looking in there to see if I have any damage.
Thanks for any help.
Boowho??
P.S. OBTW, that was probably our entire allotment of rain for the next 6 months or more.
boowho is offline   Reply With Quote
Old 03-02-2014, 10:44 AM   #2
tmmar's Avatar
Boo,
Sorry to hear about the terrible weather. Maybe we could trade you about 9 inches of snow for the rain! (LOL!)
That aside, the white upholstered portion of the button is a cover that pops off exposing a screw head. You can then remove the screws and the panel should come off. You probably will need to remove the fans also.
Good luck,
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 03-02-2014, 10:48 AM   #3
Originally Posted by tmmar View Post
Boo,
Good luck,
Tom
Thanks Tom.... That was the info I was looking for.
Bill
Old 03-04-2014, 07:40 PM   #4
Well, have gotten everything torn out (shades, valences, everything) and found the leak. Had to dry out the overhead 'headliner' panel and wring about a gallon of water out of the sponge rubber backing.
Start putting it all back together in the AM. Lotsa work, but I figured I've saved about $400; can use that to buy more "toys"...
Boowho??
Old 03-05-2014, 07:55 AM   #5
Any Pic's Bill on where the leak was and showing everything apart. Might be useful for the future.....
James
James
2008 Berkshire 360QS-40
"If you can't fix it with a hammer, you have an electrical problem"
speedmerchant is offline   Reply With Quote
Old 03-05-2014, 08:57 AM   #6
silver's Avatar
boowho
Where did you find the leak? The only thing I can think of over there is the windshield seal or radio antenna driver side roof. Did you find all the wiring in the driver side A piller as well as the AC drain? A lot of wires run down that spot. I had a bundle that were unterminated and hot as well.
silver is offline   Reply With Quote
Old 03-05-2014, 01:30 PM   #7
Originally Posted by silver View Post
boowho
The leak was (probably) where the end cap meets the main roof line; haven't flooded the area yet again to make sure I'm dry. But that was the area I was spraying when the DW hollered. It also showed deterioration of the existing sealant.
There are quite a few wires behind both pillars (left and right). There is a large red hose (maybe electric cable) down the left side. I assumed it was the "hot" 12 volts to the genset starter.
If it's a hose I'll feel better; two big lag bolts that hold the outside mirrors on come thru right there and could possibly rub thru the insulation causing a fire.
That may seem like a longshot, but a 5th wheel camped next to me last winter had such a screw thru the flooring and against a 110 volt cable. Two years of walking over the spot had caused the screw to "eat" thru the insulation and DID start a fire.
Speedmerchant, I'll do as you suggested RE: pictures.
Boowho??
Old 03-05-2014, 01:34 PM   #8
Leaks!!!!!
This is where FR found my leak. It was coughs before any damage was caused.This is right above the driver window. Click image for larger version
Name:	ImageUploadedByForest River Forums1394048082.105055.jpg
Old 03-05-2014, 01:35 PM   #9
tmmar's Avatar
Bill,
That red hose sounds like it is part of the central drain for the air conditioner. Take a look under the front corner on the drivers side of the coach. I think that you will see where the red tube comes out.
Hope you solved your leak.
Tom
Tom and Margaret
Old 03-05-2014, 08:01 PM   #10
silver's Avatar
boowhoo
The red line is the AC drain. If you have been using your front AC you may want to look it over and be sure a screw has not punctured it and it is nit draining into the wall.
I forgot you had the new style mirrors. Does it look like there is gasket behind the mount on the outside? I would look there before I would go after the cap seam. I can see someone forgetting a gasket when installing the mirror.
leak
