Old 07-11-2014, 09:34 AM   #1
stephencamiolo's Avatar
Leaky valve
The washer valve on the outside bay of our coach is leaking this morning!
Anyone know where to pick up the plastic seating that's inside?
Name:	ImageUploadedByForest River Forums1405089259.370605.jpg
stephencamiolo is offline   Reply With Quote
Old 07-11-2014, 10:07 AM   #2
If it's out of the bottom threaded area I'd use Teflon tape.
Jc
2014 400BH-60
jcowles3 is offline   Reply With Quote
Old 07-11-2014, 10:08 AM   #3
tmmar's Avatar
Do you know what it looks like? Home Depot or Lowes may carry something that can be used.
Tom and Margaret
2014 Berkshire 390bh-60
Old 07-11-2014, 10:08 AM   #4
Campin Cajun's Avatar
All I can suggest is if you can see a name brand on the valve itself and try to order on from the company or contact FR for it. Looks like some teflon tape was added at one point.
2013 Berkshire 390 BH
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 07-11-2014, 10:26 AM   #5
Yes I added Teflon tape to the threads however it leaks from the top. Heading to a RV store now!
Old 07-11-2014, 10:36 AM   #6
You'll need a pex crimper to re-attach a new valve to the line if you replace it with the same... They may have a compression style one that might fit and not require pex tools
Jc
2014 400BH-60
Old 07-12-2014, 04:50 AM   #7
Thanks for the tips! When the tech filled the tank he overfilled it blowing out the diaphragm causing it to leak from the vent! I found a two stage regulator and replaced it today. All's well.
Lesson learned: observe the guys filling my propane so they don't overfill and carry a extra two stage regulator on the coach!
Thanks again
Stephen
Old 07-12-2014, 08:30 AM   #8
tmmar's Avatar
Stephen,
Not sure how they can over fill the tank. The hose that they use (at least the ones at Flying J) has a nozzle on it that shuts off when the tank is full like the nozzle on a gas pump. How did you arrive at the conclusion that it was overfilled?
Tom
Tom and Margaret
Old 07-12-2014, 08:47 AM   #9
Originally Posted by stephencamiolo View Post
The washer valve on the outside bay of our coach is leaking this morning! Anyone know where to pick up the plastic seating that's inside?
Are you sure it's not an "O" ring or washer?
leak
