Leaning Right -- Tire Pressure??
Hi all,
Just bought our first coach, 2016 38a.... Bought it and headed to Michigan (from AZ). Ended up stopping by Elkhart and spent two days with Dave, Scott, Andy & Bob! I can't speak highly enough of these guys and the pride they take in their work!!!
On to the subject.....while at the plant they 4 point weighed (and realigned) our coach since we had it loaded. I had front tires at 100psi and rears at 95psi per their suggestion. I noticed our coach seems to lean to the right from behind. After looking up the Michelin RV tire inflation chart I need some help.
Should I be running all for points at different pressures?
My RR weight 1,200 lbs more than my LR.
Should I be running my RR at 103psi and my LR at 84psi?
Seems like that would correct the lean to the right?
My LF is 1,150 lbs heavier than my RF so should my RF be at 80psi and LF at 110psi?
Thanks in advance for any and all help/clarification.... I want to keep my family safe!!
--Nathan
