Old 11-22-2015, 02:54 PM   #11
Crusadernoob's Avatar
A few hours of below freezing shouldn't be enough to actually freeze anything, it needs to stay below freezing longer than a few hours to cause damage, if it's getting above freezing during the day and only below freezing briefly, I wouldn't worry about it. Below freezing all day, I'd winterize.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 14
Crusadernoob is offline   Reply With Quote
Old 11-23-2015, 01:14 AM   #12
Be careful ... if you look at the expansion coefficient of water it actually shrinks or contracts as temp decreases .... except ... very near the freezing point. It is actually very close to the freezing point were your risk is highest
lefaivre is offline   Reply With Quote
Old 11-23-2015, 01:47 AM   #13
Witch Doctor's Avatar
I always put 1 heater in the unit and 1 heater in the storage area set at 45, then you will be just fine with the tank heaters on. I have only winterized once and that was last year when the temps in the day where going to stay below freezing. Other then that it works great.
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-23-2015, 08:34 AM   #14
BamaBob's Avatar
One final tip - put a shop light or some other source of heat in your water manifold compartment - that should keep the pipes from freezing
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 11-23-2015, 09:13 AM   #15
SlowrideHD's Avatar
I don't winterize my fifth wheel. I just turn the heat on and set it to 40 degrees F. The HP runs down to about 35 and the gas furnace kicks on below that. I only used one 30lb tank of propane last winter. I am in north Alabama so the winters aren't very cold except for a few weeks in Jan-Feb (usually). The warm air circulating keeps everything from freezing. It's a lot less trouble than blowing out lines or using anti-freeze. And it's always ready to go.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
SlowrideHD is offline   Reply With Quote
Old 11-23-2015, 07:06 PM   #16
I-RV's Avatar
I believe that one needs to deal with the peculiarities of their rig. The many suggestions from non-Berkshire posters may not be applicable. For instance, the rear mounted tankless heater and rear bath Berkshire models are not going to be helped with heaters in the water bay, tank bay, cargo bay and living area.
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 11-30-2015, 08:01 AM   #17
stephencamiolo's Avatar
Thanks everyone for the input!
I was able to keep my coach from freezing with all the tips. Heading south to Florida tomorrow.
stephencamiolo is online now   Reply With Quote
Old 11-30-2015, 08:42 AM   #18
tmmar's Avatar
Have a safe trip and enjoy the warm weather!!
Tom and Margaret
2014 Berkshire 390bh-60
Old 11-30-2015, 12:20 PM   #19
mikeborny's Avatar
Just had my coach winterized for winter. How do you winterize a tankless water heater? I had lines blown out and antifreeze run through all the lines. Am I missing something regarding the tankless waterheater?
Mike & Amy + 3 and the dogs!
2014 berkshire 390bh-40
mikeborny is offline   Reply With Quote
Old 11-30-2015, 02:15 PM   #20
tmmar's Avatar
Mike,
What you did should take care of the water heater. Nothing else to do to winterize them.
Tom and Margaret
power
