Old 04-09-2015, 01:37 PM   #1
Leveler challenges
Good day all...first time poster
Have an 09 Berk 39BH with a weird leveler issue. Weird that they stopped working however the pump is still running. It works fine to extend and retract the two front slides so I am thinking this has to be a valve of some kind.
Anyone else experience this?
Thanks!
B
PimpmyBerk is offline   Reply With Quote
Old 04-09-2015, 04:45 PM   #2
Campin Cajun's Avatar
Welcome to the forum and the Berk family. It sounds like a valve problem to me also or electrical not sending the signal to the two front jacks. Does the problem occur when you try them individually or when pushing auto level?
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 04-10-2015, 09:41 AM   #3
Thanks Cajun. None of the jacks will operate but the pump/motor will engage and sound like it is trying to do something. Leads me to think it has to be a valve. Prior to the issue all four jacks worked fine whether using auto level or individual adjustment. No leaks from the jacks that I can tell and once deployed there was no "settling". The fact the slides are still working means it as to be some sort of valve I think.
Old 04-10-2015, 10:05 AM   #4
tmmar's Avatar
Pimp-
Welcome to the forums! Can't really add to what has been tried but you should give Equalizer a call and see if they can assist you in any way.
Good luck!
Tom and Margaret
2014 Berkshire 390bh-60
Old 04-10-2015, 10:09 AM   #5
Thanks, thats the next stop.
Old 04-10-2015, 10:54 AM   #6
So, just otp with Randy at Equalizer. First thing to check is a control/fuse box that will be located somewhere in between the pump assembly (back left compartment) and the input unit on the dash. Its 2 inches tall, 5 inches wide and 8 inches long. Has two wire harnesses going into it.
I know it is not located in the chassis wiring compartment front left. Any ideas? I thought maybe it is mounted underneath the dash control unit but don't want to pull that apart if someone knows different.
Thanks!
Old 04-10-2015, 11:07 AM   #7
tmmar's Avatar
This was posted about non-working running lights but maybe there are other fuses in the same box that will control the levelers. Hopefully the fuse will be in there.
'Well, all is fixed, thanks to the crew at forest River. Randy's guys changed out a fuse in the fuse box located in the Inverter Compartment. The fuse box is located up on the top of that compartment, you might say it is a double secret hidden location that only a person familar with the coach would know about as it is not in any documentation I have. '
Tom and Margaret
Old 04-10-2015, 12:01 PM   #8
Thats a good tip, I will check over there. Whenever I get this all traced out i will let you guys know in case anyone else experiences it. FYI, it would not be a valve issue as I understand it now since each jack has its own individual valve.
Old 04-13-2015, 09:11 AM   #9
Just a quick update. I located the control box. It is mounted in between the frame rails on the "roof" of the pass through storage compartment. I crawled in there on my back looking for it and spotted just a few minutes ago. After I get into it I will update.
Old 04-24-2015, 04:22 PM   #10
Final update on this, the box contained five fuses that were all intact. I wiggled them a bit, replaced the box and now all of the jacks are working. No clue why, but it is working.
