Paul - When I had a problem with my sofa slide, I got guidance from Rand at Lippert. He is very good. The solenoid valve may not be the problem, but it is the least expensive item. Randy had me swap valves between a known good channel and the suspect one. A little fluid came out, so be prepared to place something like aluminum foil to guide to funnel the fluid. This was not my problem, but was the hydraulic ram. Besides the solenoid valve, your problem may very well be the jack itself. Give randy a call. - Hank
Gale & Hank- 2012 Berkshire 390BH
