Old 09-28-2015, 12:14 PM   #1
Leveling jack creep
Here's a Monday morning head scratcher. Lately I've noticed that my rear drivers side leveling jack has slowly been retracting. About every two to three days I notice that the jack is about 4" off the surface.
Has anybody else experienced this? Any idea what causes this. The other three jacks are acting fine.
Paul
Paulie Boy is offline   Reply With Quote
Old 09-28-2015, 12:35 PM   #2
silver's Avatar
it is the valve on the pup for that jack. $80 part. Mine did that on passenger side. had it fixed at the factory. Swap valves with another jack and see if the problem moves. It is easy. Remove electric cellinoide and use wrench to unscrew valve. almost no fluid was lost when done with jacks up.
silver is offline   Reply With Quote
Old 09-28-2015, 12:58 PM   #3
Silver, I don't understand "pup"? Do you mean the main pump? And, how does one know which valve it is?
Paul
Old 09-28-2015, 01:32 PM   #4
accumack's Avatar
Checkout this thread.
http://www.forestriverforums.com/for...oil-85210.html
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 09-28-2015, 01:50 PM   #5
I-RV's Avatar
Paul - The hydraulic channels are color coded. Check out the manuals at ...
Technical Support Center and Videos
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 09-28-2015, 02:42 PM   #6
jmgllt's Avatar
Good info
jmgllt is offline   Reply With Quote
Old 09-28-2015, 07:21 PM   #7
Ok, so I've read everything, found the color coded valves but the lingering question is what are the diagnostic tests to determine the fix?
Paul
Old 09-28-2015, 08:59 PM   #8
silver's Avatar
Put the jack down and see if it creeps. If put under load will know within an hour or so. ie jack down.
and pup is pump typed to quickly
Old 09-29-2015, 07:25 AM   #9
I-RV's Avatar
Paul - When I had a problem with my sofa slide, I got guidance from Rand at Lippert. He is very good. The solenoid valve may not be the problem, but it is the least expensive item. Randy had me swap valves between a known good channel and the suspect one. A little fluid came out, so be prepared to place something like aluminum foil to guide to funnel the fluid. This was not my problem, but was the hydraulic ram. Besides the solenoid valve, your problem may very well be the jack itself. Give randy a call. - Hank
Old 09-30-2015, 09:27 PM   #10
edgewant's Avatar
Thought the Berkshires used Equalizer hydraulics.
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 10-01-2015, 07:25 AM   #11
Lippert is equalizer.
Paul
Old 10-01-2015, 08:29 AM   #12
edgewant's Avatar
Paul
I respectfully disagree. Lippert is LCI and Equalizer is a Days Company. Both are located in Elkhart but are separate entities....as far as I can tell.
edgewant
Old 10-01-2015, 08:41 AM   #13
A32Deuce's Avatar
They are separate.
A32Deuce is offline   Reply With Quote
Old 10-01-2015, 05:48 PM   #14
I-RV's Avatar
I agree edgewant. My bad on some of my post that stated Lippert - Hank
leveling
