Old 01-27-2015, 11:17 AM   #1
RKC02's Avatar
Leveling system calibration
My Berk 390-RB is parked on a concrete pad that is fairly level. Thinking I needed the jacks for stability I deployed them and discovered we were more un-leveled than without them. Several try's produced same results. Jacks are retracted now and coach very close to level - is there any reason to use the jacks if not needed to level?
I guess they need calibration and will see if Freightliner will do it while we are in for service.
RKC02
2014 390RB-60 "The Shire"
RKC02 is offline   Reply With Quote
Old 01-27-2015, 11:52 AM   #2
AREA51's Avatar
My jacks have a routine to set the NULL. Read your manual and it should address the procedure. It is simple and should be done regularly.
GOOD LUCK
AREA51
AREA51 is offline   Reply With Quote
Old 01-27-2015, 03:08 PM   #3
JTN8's Avatar
X2, I reset my null about twice a year. Very easy to do and the instructions can be found online or in your manual.
Jason
2014 Berkshire 390BH
2011 cadillac SRX
Old 01-27-2015, 04:04 PM   #4
NV245's Avatar
Even after resetting the null I find that in some spots, manually leveling the coach can be more desirable and is something that should be learned. IMHO.
NV245 is offline   Reply With Quote
Old 01-27-2015, 06:59 PM   #5
dan-nickie's Avatar
I agree. Last trip I started manually leveling almost every time.
I found I could do it and stay closer to the ground.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 01-27-2015, 08:53 PM   #6
RKC02's Avatar
Thanks to all for the info. Just a double-check: is it okay to remain without the jacks deployed? Only difference is slight movement when walking in the coach. Obviously the jacks provide more stability. Only other reason that comes to mind is removing some weight from the tires since we will be stationary for next three months.
RKC02
leveling
