Old 02-09-2019, 01:17 PM   #1
erniet's Avatar
LG TV above the fireplace
I'm not much of a TV watcher. Got this MH last year. We've been trying to watch TV for the past month. Several times after about an hour or so the TV goes Black and then after a few seconds it comes back on. It doesn't matter whether a TV program of if we were using the DVD.
Another problem we've had is sometimes the speakers have had a loud static come out once in a while, again after the TV has been on an hour or so.
Do I have something going wrong with the TV or do I have something set wrong?
2014 Berkshire 400QL; sometimes towing 2007 Silverado and other times
towing my 20' Aluma trailer with a vehicle on it.
erniet is offline   Reply With Quote
Old 02-09-2019, 01:47 PM   #2
Denver To Yuma In 90 Days
Best way to find out is to hook up another TV in that spot and see what happens.
And try that TV in another spot...
JohnD10 is offline   Reply With Quote
Old 02-09-2019, 01:53 PM   #3
Witch Doctor's Avatar
It sounds like it is shutting off on the heat sink board. Is it a RCA? I had the same problem. There's a heat sink on the board. It over heats and it shuts down until it cools, I bought a Sony and replaced it, problem ended.
Coachmen M/H
Concord
2018 / 300 DSC
Old 02-09-2019, 10:21 PM   #4
Dragonship Captain
Oscarvan's Avatar
Yeah, sounds like the TV is having Maalox moments when it gets toasty. Swap out another unit is the test....
Read about our 2017 38A: https://dragonship.blog/
Oscarvan is offline   Reply With Quote
Old 02-10-2019, 02:51 PM   #5
DVD
We had a staple through the cat 5 on our XLT. Try hooking DVD straight to TV without any other connections. Our staple caused the exact same symptoms but in bed room TV.
Good luck.
OnBarrowedTime is offline   Reply With Quote
Old 02-10-2019, 03:33 PM   #6
bloodybill
BLOODYBILL's Avatar
i say just don,t get a vizio tv
they are cheap but the long jeapardy is junk
you will probably open up a another can of worms
BLOODYBILL is offline   Reply With Quote
Old 02-10-2019, 05:21 PM   #7
Retired JSO's Avatar
I happen to own 6 Vizio TV’s. Not junk at all. They are cheap but haven’t failed me like 2 previous Samsung’s crap. I have a 55” and a 32” in the new fifth wheel after I threw out the stock Furrion junk. Have a 19”, 43” 55” and a 70” in the home port. The oldest being 7 years. I might add, Vizio sells both tv’s and home theatre systems. Tv’s have a tuner, home theatre are monitors. The E series is better than the D series.
Retired JSO is offline   Reply With Quote
Old 02-10-2019, 08:18 PM   #8
TVs are like RVs
TVs are like RVs--they are assembled from a series of components procured from other manufacturers.
The backlight (CCFL or LED) comes from one of about six sources. The LCD itself comes from one of about six or seven, all in the far east. The semiconductors--or even the assembled motherboards--come from maybe another half-dozen.
The result is that the quality is pretty much the same no matter the source. There are some differences in the LCD types--easy to read on the box before you buy. Otherwise generally not too much difference. Same thing is true for consumer-grade audio gear.
Larry
Larry-NC is offline   Reply With Quote
Old 02-10-2019, 10:52 PM   #9
bloodybill
BLOODYBILL's Avatar
hi thats great
i got to say you are the first person to say you have had no problems with the cheapest brand i know of out there
Old 02-10-2019, 10:59 PM   #10
I've had seven Vizio's in the last 15 years...
Still have four of them...two in my 5'ver.
My favorite brand of TV's!
fireplace
