Old 07-08-2015, 08:56 PM   #21
accumack's Avatar
Have you tried the map lights in case the switch is mis-marked?
accumack is offline   Reply With Quote
Old 07-09-2015, 10:28 AM   #22
KennyGolub's Avatar
I haven't tried the map lights while looking to see if it affected the backup/(docking?) lights, but the map lights do turn on the map lights.
Ken & Laurie
2022 Riverstone Legacy 39RKFB
2022 RAM 3500 Laramie Dually
KennyGolub is offline   Reply With Quote
Old 07-09-2015, 10:31 AM   #23
KennyGolub's Avatar
Originally Posted by foretm View Post
Is it part of the headlight switch or dash light dimmer where if you roll it up beyond the dimmer portion it turns on the interior lights? maybe its hooked to something like that. No clue just guessing.
Yes, I thing I turned, pushed and twisted every knob/button I could find.
I just called a local Freightliner (one actually marked as Oasis) and they said their priority is trucks. So I called a different one that isn't marked as Oasis, and they were much friendlier on the phone. They said it was probably the body builders problem. So I guess I'll try and contact FR and see what they say.
Thanks.
Ken & Laurie
Old 07-09-2015, 10:33 AM   #24
KennyGolub's Avatar
Originally Posted by silver View Post
Hi Kenny,
If they are Dock lights they would be located on the side of the coach just behind the rear wheels. I thought Forest River discontinued them on the new coaches but not sure.
Where are the lights that are staying on? If in back of coach then they are backup lights.
My backup lights will not come on unless the engine is running on my 2008 Berk.
I would say head back to Gafney.
Definitely backup lights. Now I'm trying to find out if Freightliner or FR is the company to cover it.
Ken & Laurie
light
