Old 10-25-2014, 04:33 PM   #11
Fulltime in our Berkshire
KennyGolub's Avatar
Originally Posted by JJvike View Post
Isn't 150 high? My 2 gauges never get that high. Hmmm....
I may been rounding up......my bad.
This is all great information. Thanks to all !!
KennyGolub is offline   Reply With Quote
Old 10-25-2014, 05:37 PM   #12
I did the same thing the day after I read a thread about the "pogo" effect so I almost immediately knew what was wrong. I did manage to ram my exhaust extension into the rear cap coming out of my driveway before I could safely stop and hit the retract button again. A little fiberglass work and we are as good as new.
Dan
2015 Entegra Anthem 450HP-1250ft lbs of torque
2015 Jeep Grand Cherokee
Roadmaster Falcon 2 All Terrain
SMI Air Force 1
seeg is offline   Reply With Quote
Old 10-26-2014, 09:48 AM   #13
Never ever move the MH without a final walk around. After all the checks are made in the cockpit I always do a walk around and check doors ride height awnings toad just a last second check. Ride height I but my fist between the top of the tire and the fender on all four wheel wells. Silly because I've checked it all once but I never worry about anything when I pull out. I am a private pilot and I treat my last walk around like a preflight inspection.
Old 10-28-2014, 08:02 PM   #14
Kelsma03's Avatar
We did the same thing once. After you pull the jacks up wait several minutes until the air bags inflate. I usually stand outside and watch the coach about the back tire. Sometimes you can hear a creaking sound then the woosh... then you are good to go.
Kelsma03 is offline   Reply With Quote
