Old 10-25-2014, 08:52 AM   #1
Fulltime in our Berkshire
KennyGolub's Avatar
Like riding a mechanical bull
Ok....took the Berk out for the second time since I owned it to add fuel.
I was tossed around in the seat like I was riding a mechanical bull. Twice, I would have been thrown from the seat if I didn't have a seat belt on.
Please tell me what I did wrong. I've never had air bags before. Is there something with that I was supposed to do before leaving?
Thanks,
Ken
KennyGolub is offline   Reply With Quote
Old 10-25-2014, 09:00 AM   #2
"Retract All" on your jacks. You may have a sensor reading that you have a leveling jack down even if they are up.
CT Camper is offline   Reply With Quote
Old 10-25-2014, 09:05 AM   #3
Berkshire 390QS
NO3putt's Avatar
It has happened to many of us, air bags not filled up. This is the process we use.
1. Slides in
2. Start engine, let run until hear air release (both air gages above 120)
3. Raise jacks
4. Wait again until we hear air release
5. Walk around and check distance between tires and fenders. (about 1" with air bags deflated, about 4 to 5" when aired up)
The pogo ride is not fun at all, just make sure you have the 4 to 5" gap between tires and finders
Skip
NO3putt is online now   Reply With Quote
Old 10-25-2014, 09:58 AM   #4
tmmar's Avatar
Ken,
As Skip has said, your air bags did not inflate and has happened to most of us. I usually push the retract all twice. After that, I pick out some spot, either out the windshield or door window or drivers window frame and some spot outside that I can use to tell if the coach is raising and the air bags filling. Takes some getting used to but it works.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 10-25-2014, 10:03 AM   #5
It was your air system. Even though the system quits alarming around 90, your rig is not ready for the road. I, too, rode the wild ride and a nice gentleman was nice enough to help me with my rookie status. My gauges need to read about 110-120 to be ready. There are more of us newbies that have done this than will probably admit.
JJvike is offline   Reply With Quote
Old 10-25-2014, 10:53 AM   #6
<- Rookie myself not long ago and did the same thing.
Glenn
2014 Berkshire 400BH
2014 Jeep Rubicon Unlimited
grt1014 is online now   Reply With Quote
Old 10-25-2014, 12:53 PM   #7
KennyGolub's Avatar
The first thing I looked at was the air pressure gauge and the were both just over 150. So I'm guessing the jacks weren't all the way up.
Speaking of jacks.......I am going to leave them fully retracted for the winter. I'd rather have them stuck up than stuck down. Should I let the air out of the bags also ?
Thanks everyone....this forum is great !!!!!!!!!!!!
Ken
Old 10-25-2014, 01:29 PM   #8
tmmar's Avatar
Ken,
The air bags will bleed down over time by them selves. No need to try and bleed them manually. Also, I made 4 wooden 'stands' to go under the jacks. They are just a piece of 4x4 that just fit under the jacks when the air bags are full. This way, when the air bags bleed down, the jacks will sit on the 4x4's and the weight of the coach will be supported by the 4x4's and not the empty air bags. Just what I do when the coach sit for the winter.
Tom
Tom and Margaret
Old 10-25-2014, 02:53 PM   #9
Isn't 150 high? My 2 gauges never get that high. Hmmm....
Old 10-25-2014, 03:20 PM   #10
tmmar's Avatar
JJ,
Good catch. They should be around 125psi. I read another thread (in this forum I think) where the gauges were reading 150psi and it caused a problem with the system. If the gauges continually read 150 then Kenny should get the system checked.
Tom
Tom and Margaret
