Old 12-15-2015, 04:24 PM   #11
Campin Cajun's Avatar
Well Mr. Kustom you can buy whatever you like, if you ever need to that is.
Not sure what you mean by fragile, if you mean expensive, A new Wrangle is not much less expensive than a SRX or MKX.
I own both Wrangler & SRX so I know what I'm talking about.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 12-15-2015, 05:24 PM   #12
Kenny kustom's Avatar
As mentioned above you...
Wrangler.
Solid axle.
Mechanical transfer case.
No wheel lock
Cheap to repair.
Not " fragile"
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
I am nice!
2017 Dynamax Isata 4
Old 12-15-2015, 05:36 PM   #13
JEEP = Just Empty Every Pocket
Solid axle not an advantage for a toad.
Mechanical transfer case is held and operated by a small plastic piece that breaks easily. It's hard to buy one, much less replace it. Trust me, I've done it twice.
No wheel lock on the SRX either.
Ask ANY Jeep owner if it's cheap to repair.
I love my Jeep, I tow it just about every time we go camping.
Your argument in invalid.
Old 12-15-2015, 05:40 PM   #14
Lincoln MKX for a Tow Vehicle
I have no idea what you are talking about. Jeeps are inexpensive to modify and build. Lol.
My jk.
. Click image for larger version
Name:	ImageUploadedByForest River Forums1450222804.711958.jpg
2016 Sabre 36QBOK
I am nice!
Old 12-15-2015, 05:59 PM   #15
As a former Ford and Chrysler tech..
I would rather fix my jeep, than a Lincoln.
But hey!!
Name:	ImageUploadedByForest River Forums1450223984.729419.jpg
2016 Sabre 36QBOK
I am nice!
Old 12-15-2015, 08:33 PM   #16
RKNOLA's Avatar
from a woman's point of view: MKX hood very hard to see over. Seats uncomfortable. Center console height very "purse unfriendly". Large opening under center console not really big enough for a purse.
Jeep 2 door: not a lot of passenger room in backseat.
Jeep 4 door: plenty of passenger room, rides better than 2 door Jeep. But is heavier than 2 door Jeep.
Jeep great in snow/mud.
Jeep Grand Cherokee: Pure luxury! More expensive, yes but looks great! Also usually easier for women to get in/out of (height wise) than Wrangler.
Just my opinion.
Karen
Rick and Karen
2018 Berkshire XL 40C
2011 Honda CR-V toad FB
RKNOLA is offline   Reply With Quote
Old 12-15-2015, 08:42 PM   #17
I actually drive the truck.
Since I traded her Lexus in on the truck, she now drives the jeep.
She loves it.
2016 Sabre 36QBOK
I am nice!
Old 12-15-2015, 09:11 PM   #18
JTN8's Avatar
Originally Posted by Campin Cajun View Post
Do you already own the MKX? If not, look into the Cadillac SRX instead.
X2!!
I've been towing a Cadillac SRX for
4 years now and love it! Hooked up to the back of the motorhome in just a couple minutes tops! Turn the car off, put it in neutral and that's it! No battery to disconnect or charge since the car is completely off. Yes they are push button ignition but once you **** it off, lift the shifter boot and press the release button and shift into neutral. Then tow!!!
Jason
Old 12-15-2015, 11:09 PM   #19
If you ever have a chance to buy a Hummer H3, they are really great toads. Too bad they are not being made anymore.
I have used 2 different Saturns, a Suzuki, a Nissan Frontier, and my H3 has been following me since 2006. The Hummer has outlasted 2 different coaches and now it's coach number 3.
The Hummer can be setup easily with base plates from any of the manufacturers. It has an electronic transfer case that can easily be put into neutral. There is no steering lock. So, you hookup and put the transfer case into neutral, put the shifter into park, pull the key and away you go. To avoid battery drawdown, I use a "jump start" battery to power the Brake Buddy.
When you reach your destination, you have a good vehicle to go anywhere you want to go including off-road if you're into that.
And, yes, it's heavy. Close to 5,000 pounds. But I never had any problems towing it around. That's why I chose the e450 cutaway chassis for my Class C - the hitch is rated for 7500 pounds.
Wayne Lee
Out West Somewhere
2016 Sunseeker 3050DS towing 2006 Hummer H3
WayneLee is offline   Reply With Quote
Old 12-16-2015, 01:42 PM   #20
Originally Posted by Mmnsc View Post
Surprisingly it only takes about 5 minutes to hook up totally to the motor home.
I originally bought a Demco dolly but when the dealer went to put the Explorer on the dolly, it turned out the car was too wide to fit between the dolly fenders. Dealer checked every dolly manufacturer to see if they can accommodate a Ford Explorer and it turned out none were available. I had no choice but flat tow 4 down. The best decision I ever made and happened to me. Flat towing is extremely easy and quick to set up.
X2. The setup on my Explorer seemed like a pain when I first investigated it, but it really is no more than a 5 minute task. As for having to run the Explorer engine every 6 hours, no big deal - I never drive more than 6 hours straight in the motorhome, so it is a non-issue. Plus, no trailer or tow dolly to deal with at a campground.
DocP is offline   Reply With Quote
tow vehicle
