Old 12-06-2015, 10:27 AM   #11
accumack's Avatar
Originally Posted by I-RV View Post
Joe, here is a little tidbit: Ehen driving, the driver can check the RV's position within the lane by looking at the painted lines in the side view mirrors and also the rear camera.
I have added a painted dot (with nail polish) in the lower left windshield. When I move the RV to place the dot on the lane's left painted line, my RV is about a foot from the line, This is handy, like when you are in the center lane and a 18-wheeler on both sides and you can't be studying mirrors. Good for narrow lanes as well. I only revert to the dot for critical situations.
I would start by experimenting with some masking tape dots, driving and seeing were they should be moved. Once you have the perfect spot, dab a painted dot there.
Just a little Yuletide Tidbit to you - Hank
That works until you move the seat. I'm never able to get the seat back to the same position.LOL
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 12-06-2015, 10:42 AM   #12
I-RV's Avatar
Agreed, but I don't have the seat problem and it works for me.
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 12-06-2015, 10:45 AM   #13
I-RV's Avatar
I just remembered, that if I would put the dot on the line immediately in front of the RV, then it was very sensitive to seat position. I generally have the dot on the line about 50 ft. in front.
Hank
Old 12-06-2015, 01:05 PM   #14
A32Deuce's Avatar
If you look straight out the windshield, you will be in the center of your lane. Maybe 6 to 10 car lengths in front.
A32Deuce is offline   Reply With Quote
Old 12-06-2015, 01:25 PM   #15
I can only imagine the headache I would have focusing on a dot on the windshield.
There is a gap between the speedo / tach module and the left instrument module. Keep that gap on the line to the left of the coach. Use that gap as a check tool to occasionally make sure you are just inside the line on the left.
Paulie Boy is offline   Reply With Quote
Old 12-06-2015, 01:39 PM   #16
dan-nickie's Avatar
This works for me too. Figured that out not long after I got the coach.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 12-06-2015, 05:04 PM   #17
I-RV's Avatar
X3 Paul, I used that originally, but a nice 3/4" bullseye that you can place on the line further out seemed to even work better.
Hank
Old 12-07-2015, 10:18 AM   #18
BamaBob's Avatar
Joe,
GMTA! We just have different solutions
This is what I got - slightly more expensive than your solution but I want to be able to carry the minimum required keys possible - AND I like the fact that I can take the ignition key off the ring and not have a bunch of keys dangeling on the console
http://www.amazon.com/gp/product/B00...ilpage_o04_s01
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is online now   Reply With Quote
Old 12-07-2015, 04:34 PM   #19
Originally Posted by BamaBob View Post
Joe,
Bob that looks like it will do a good job also. I like your idea about having a single ignition key on a ring to avoid all the banging of keys. I'm still looking for a vendor to get Freightliner ( stock looking ) ignition keys made. Tried FR but they were in excess of 60.00 each I believe ( don't know why not being an electronic key like an auto that unlocks doors and trunk ).
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 12-08-2015, 10:46 AM   #20
gasman94's Avatar
Not to change subject here, but does everyone here always lock their doors? Like if you're just going for a short walk, etc.? If I feel comfortable with my neighbors/surroundings, I will close the door, but not always lock it unless I will be gone for an extended period.
Rich
gasman94 is offline   Reply With Quote
