Old 09-28-2016, 12:13 PM   #11
Originally Posted by KennyGolub View Post
When I first took my coach home, I left both house and chassis batteries "on" (switch in the 'on' position). I found the chassis batteries were way down and not charging, but the house batteries were fine. The chassis batteries went so low, I had to get two new ones.
So, I now leave the house batteries to "on" and the chassis batteries main to "off". I plug a trickle charger into an outlet (coach is plugged in for power all winter), and connect the charger to the chassis batteries directly after turning the master switch for the chassis batteries off.
I hope this explains it a little better. I've never been a wordsmith
You would think that FR would have wired so that all batteries house and chassis would have been charged by the battery charger.
Could that be why, when I start up that I get a "Low Voltage" indication on the FL instrument bar?. Seems like FR should come up with a way to do that without us having to put a separate trickle changer on the chassis batteries.
Joe & Kathy
2017 Dynamax DX3 37BH
Toad: 2016 Ford Edge
2016: days camped 60
2017: days camped 39
joet19711 is offline   Reply With Quote
Old 09-28-2016, 12:53 PM   #12
Mmnsc's Avatar
JoeT
When you start your engine the low voltage indicator will come on because as Cummins has stated there is a heater in the intake to warm the air. It draws a lot of amps and pulls down the voltage from the chassis batteries. Perfectly normal. Try to increase the idle to speed up the process. The engine needs to get to about 100 degrees before the voltage will stabilize.
Marty
Mmnsc is offline   Reply With Quote
Old 09-28-2016, 01:09 PM   #13
Originally Posted by Mmnsc View Post
JoeT
Marty
Thanks Marty good to know that it is normal..
Joe
Joe & Kathy
storage
