10-07-2012, 06:07 PM
loss of power to tv sets and to two outlets.
I plugged in a portable heater into the outlet below my bedroom Tv in my 2008 Berkshire. Shortly thereafter I lost power to the Tv in the kitchen and the bedroom as well as to two wall outlets nearby. From what I can see all the circuit breakers are okay and all the fuses look good. Is there another area where I can find a circuit breaker that has been tripped? Please advise.
10-07-2012, 06:15 PM
Phat Phrog Stunt Crew
You might want to check your GFI receptacles and see if any of them have tripped. Lots of time, they feed other outlets from a single GFI.
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
10-07-2012, 06:36 PM
Many circuit breakers look OK and in the ON position but in reality have been tripped. Find the correct circuit breaker for the television and flip it to off and then back to on. I’ll bet everything will be working again.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
10-07-2012, 07:09 PM
Berkshire 390QS
If it's not the breaker, could be a wire has come off the buss bars in the breaker box. You might want to take the cover of the breaker box off and inspect. (with power disconnected) we had some come off and melted the breaker box.
Skip
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
2019: 156 days (2009 Berkshire, 390QS, and toad)
10-07-2012, 07:29 PM
I would be willing to bet that it is one of the two GFI breakers. Either the one that is found in the bath or the one in the kitchen.
10-08-2012, 03:39 PM
You pluged your heater into an outlet that is controled by your inverter. You triped the breaker on the inverter. It is a small black switch on the top of the inverter. Turn this off and back on and you will again be working.
10-08-2012, 04:37 PM
I also have an obscure GFI outlet in my front pass-through compartment, for the plug-in for the water heater. That outlet supplies one other outlet at bedside. The one time it tripped, I pulled my hair out trying to find the problem!
Fire Instructor
2022 Coachmen Leprechaun 319MB
2022 Ford Ranger toad
10-08-2012, 05:58 PM
Thanks Forum readers for your feedback. I found that the culprit was the circuit breaker on the inverter. I reset the breaker and I once again have power.
10-08-2012, 11:39 PM
Fire instructor
What year and model of Berk do you have. My unit is in storage right now so I am having trouble visualizing where it is. The on demand water heater in my 2012 390BH-60 is on the rear right. I know that I have a powere outlet in the front right compartment (the one with shelves) ... is it that compartment of the one directly behind?
I can only imagine your frustration ... I know how long I seached for the ones inside the unit itself ... would never have thought to look in basement storage for GFI.
11-01-2012, 04:53 PM
Possum
New member here. I have the same problem on my 2102 Berkshire. Is the inverter the same as a 2008? Had to use extension cords to watch TV from oregon to our trip back to Texas.....what a pain!!! Thanks for your help. Possum
11-01-2012, 07:16 PM
loss of power
Possum,
Please see the response from #6 in this thread. The inverter switch did the trick for me. Hopefully, it will work for you, as well.
11-01-2012, 07:59 PM
Possum
thanks for the reply Hark 582. I checked out the inverter and found no reset switch on top of the unit. I have a 2012 berkshire with a Magnum inverter located in drivers side back door above cord to shore power. I'll check again in morning.
11-01-2012, 08:14 PM
Magnum Reset
This is the location on mine. See picture
11-02-2012, 05:04 AM
In my 2008 Berkshire, the inverter is located in the rear compartment on the passenger side. It is the compartment directly behind the batteries. The switch is on the top of the inverter. Good luck!
11-02-2012, 09:50 AM
possum
I checked the inverter this am. Sure enough I found the reset switches. There are two one for ac in and one says 12 V out. Both are set and i could hear the inverter running. They are rocker switches and I tried to turn them on and off however they won't budge. I don't want to force them and I can see the green light flashing on inverter in 2 second intervals. I also have a remote switch in bath. I pressed the on/off switch and the inverter light came on but still no power to the tv's including the one outside. Any suggestions?
11-02-2012, 05:34 PM
Berkshire 390QS
We had power problems once, thougt it was the inverter also, ended up being the wires inside the breaker box came off te power bus. If I figure out how to insert pictures would show you a melted breaker box.
11-02-2012, 05:39 PM
Thanks No 3 putt (and I hope i can avoid those in the morning) I'll check it out after golf tomorrow. Did you fix it or did you have to go to dealer? Possum
11-02-2012, 06:05 PM
Berkshire 390QS
Was on way back from AK when it happened, had to have new box shipped and rv dealer in Whitehorse CA replaced it. What's a couple of weeks in Canada waiting for box. Still waiting to see if FR is going to pay or not.
Skip
