Old 03-16-2015, 12:19 PM   #11
mTn_biKer65's Avatar
I've have a Weber Q and have considered getting the adapters to take advantage of the existing propane on my TT. Could you clarify where each of the pieces mentioned below go. Some are self explanatory but some I'm not 100% sure.
My trailer has a capped end on the propane line which I assume is where I'd tap into the propane.
Paul
Originally Posted by dan-nickie View Post
I just bought male and female for adapting my Weber Q to use the low pressure LP in the Berkshire bay.
I think all LP items were 1/4 NPT.
Just hooked them up and tested today. I see the Amazon prices have changed.
Amazon.com: Camco 57282 10' Propane Quick-Connect Hose: Automotive
Amazon.com: Camco 59903 Propane Quick-Connect Fitting - 1/4" NPT x Full Flow Male Plug: Automotive
http://www.amazon.com/Camco-59853-Pr...G8X9P4W1JJMTA6
Anderson Metals Brass Pipe Fitting, Coupling, 1/4" x 1/4" Female Pipe: Industrial Pipe Fittings: Amazon.com: Industrial & Scientific
I got the Air connector at Harbor Freight last year
There are a couple different styles of air connectors so I bought a pack of both so one of them would fit the chassis connector. I do not recall the style or specs other than it was the 'automotive' rather than 'commercial' style.
Nights camped
2007 Shamrock F19 hybrid - 2010 (22 nights), 2011 (24 nights), 2012 (11 nights)
2013 Surveyor Select 235RKS -
2012 (6 nights), 2013 (32 nights), 2014 (26 nights), 2015 (37 nights), 2016 (14 nights)
mTn_biKer65 is offline   Reply With Quote
Old 03-16-2015, 12:29 PM   #12
dan-nickie's Avatar
Paul
I'll try to post the instructions when I get home later today.
Dan
2014 Berkshire 390RB-60
dan-nickie is online now   Reply With Quote
Old 03-16-2015, 12:30 PM   #13
dan-nickie's Avatar
Originally Posted by mike.t View Post
I may be wrong but i would not think the quick disconnect fittings would be the same for LP and air. Not talking about the thread size. Those would be 1/4 NPT.
He asked two different questions.
That's why I gave two different answers.
I didn't think they would both be the same either.
Dan
Old 03-16-2015, 02:25 PM   #14
mike.t's Avatar
Originally Posted by Neanderthal View Post
Does anyone by chance know the size of the female LP quick connect for the factory installed male auxiliary LP quick connect? And does anyone know the size of the female quick connect for the Air line auxiliary connection?
By size do mean thread size or nipple size? All rv quick disconnect BBQ NIPPLE fittings are the same size. The thread size is 1/4 NPT The main gas line is 1/2 NPT.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 03-16-2015, 02:30 PM   #15
Originally Posted by TURBS View Post
I'd recommend putting in a shut off valve as well.
If the quick connect ever fails you'll know why.
Just my 2 cents.
And don't trust the quick connects to seal all that great even tho' the grill is turned off. Drained a 30# cyl. in 3 days. $26 lesson. Install and use the shut off valve.
Old 03-16-2015, 02:32 PM   #16
TURBS's Avatar
Shut mine off after each use.
Old 03-16-2015, 02:35 PM   #17
I do too now!
In fact, I turn the shut off valve off first and then the grill.
Old 03-16-2015, 03:22 PM   #18
mike.t's Avatar
Originally Posted by JTN8 View Post
The Berks already come with a shut off valve at the quick connect point.
Jason
Thank you. I have seen a RV female quick disconnect that did not have a shut off valve.Guess there may be some out there but not for RV's.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 03-16-2015, 03:25 PM   #19
My Flagstaff has a shut off right at the camper qd fitting. It has an interlock that the valve has to be off to connect/disconnect.
Old 03-16-2015, 06:07 PM   #20
Retired IT Manager (NERD)
I was able to find the LP male adapter locally at an RV dealer cheaper than amazon. Manufacturer is JR Products part number 07-30445 1/4 " MPT x Male Quick Disconnect
JR Products :: Home
The Air disconnect I did not look at yet.
Neanderthal is offline   Reply With Quote
