03-15-2015, 06:55 PM
Retired IT Manager (NERD)
LP quick connect/ Air chuck
Does anyone by chance know the size of the female LP quick connect for the factory installed male auxiliary LP quick connect? And does anyone know the size of the female quick connect for the Air line auxiliary connection?
03-15-2015, 07:10 PM
Both are 1/2" NPT.
2013 Berkshire 390BH
03-16-2015, 04:42 AM
Thank you
03-16-2015, 07:21 AM
03-16-2015, 07:40 AM
I'd recommend putting in a shut off valve as well.
If the quick connect ever fails you'll know why.
Just my 2 cents.
03-16-2015, 10:50 AM
Just my 2 cents.
The Berks already come with a shut off valve at the quick connect point.
Jason
03-16-2015, 11:22 AM
We talking air or propane here?
03-16-2015, 11:23 AM
Both.
Dan
2014 Berkshire 390RB-60
03-16-2015, 11:35 AM
I may be wrong but i would not think the quick disconnect fittings would be the same for LP and air. Not talking about the thread size. Those would be 1/4 NPT.
03-16-2015, 12:19 PM
I've have a Weber Q and have considered getting the adapters to take advantage of the existing propane on my TT. Could you clarify where each of the pieces mentioned below go. Some are self explanatory but some I'm not 100% sure.
My trailer has a capped end on the propane line which I assume is where I'd tap into the propane.
Paul
Originally Posted by dan-nickie
Nights camped
2007 Shamrock F19 hybrid - 2010 (22 nights), 2011 (24 nights), 2012 (11 nights)
2013 Surveyor Select 235RKS - 2012 (6 nights), 2013 (32 nights), 2014 (26 nights), 2015 (37 nights), 2016 (14 nights)
03-16-2015, 12:29 PM
Paul
I'll try to post the instructions when I get home later today.
Dan
03-16-2015, 12:30 PM
He asked two different questions.
That's why I gave two different answers.
I didn't think they would both be the same either.
Dan
03-16-2015, 02:25 PM
By size do mean thread size or nipple size? All rv quick disconnect BBQ NIPPLE fittings are the same size. The thread size is 1/4 NPT The main gas line is 1/2 NPT.
03-16-2015, 02:30 PM
Mod free 5er
Just my 2 cents.
And don't trust the quick connects to seal all that great even tho' the grill is turned off. Drained a 30# cyl. in 3 days. $26 lesson. Install and use the shut off valve.
03-16-2015, 02:32 PM
Shut mine off after each use.
03-16-2015, 02:35 PM
Mod free 5er
I do too now!
In fact, I turn the shut off valve off first and then the grill.
03-16-2015, 03:22 PM
Jason
Thank you. I have seen a RV female quick disconnect that did not have a shut off valve.Guess there may be some out there but not for RV's.
03-16-2015, 03:25 PM
Mod free 5er
My Flagstaff has a shut off right at the camper qd fitting. It has an interlock that the valve has to be off to connect/disconnect.
03-16-2015, 06:07 PM
I was able to find the LP male adapter locally at an RV dealer cheaper than amazon. Manufacturer is JR Products part number 07-30445 1/4 " MPT x Male Quick Disconnect
JR Products :: Home
The Air disconnect I did not look at yet.
