Old 10-12-2015, 09:49 PM   #11
LR and Kitchen Under-Cabinet Lights
Thanks, Paul. Great suggestion. FTL Help walked me through what likely actually happened, what to watch for, and provided contact info for Freightliner of Austin. Thanks again.
Johnny Bravo is offline   Reply With Quote
Old 10-12-2015, 10:14 PM   #12
So did FL agree that the bags deflated because the road was so rough? That seems hard to except.
Old 10-12-2015, 10:22 PM   #13
dan-nickie's Avatar
Originally Posted by Johnny Bravo View Post
there is a black corrugated hose (about two inches in diameter) that is hanging somewhat low between the rear axle and the rear end of the rig. There is no obvious missing bracket, and it is about 8-10 inches off the ground with jacks down
JB
Sounds like what my transmission lines have looked like since day one you
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 10-12-2015, 11:03 PM   #14
Not exactly. She said that one part of the system is a breakaway part (by design) that can be knocked out of position, resulting in deflation and the bouncing I experienced until the part was out back into place. However, I believe she thought it more likely that road debris was the cause than simply the roughness of the road.
Old 10-12-2015, 11:09 PM   #15
Old 10-13-2015, 09:06 AM   #16
tmmar's Avatar
That black corrugated hose sounds like the plastic loom that they put around the wires. If it is black plastic that has a slit in it, then that is probably what it is.
https://www.google.com/search?q=wire...wJs5bkmp5NM%3D
Tom and Margaret
2014 Berkshire 390bh-60
Old 10-13-2015, 10:34 AM   #17
15berkxl's Avatar
My transmission cooling lines also has that kind of wrap around both lines.
Wayne
Wayne
15berkxl is offline   Reply With Quote
light
