Old 05-24-2016, 10:25 AM   #1
Go Seahawks!
Subsailor's Avatar
Magnum Inverter Remote Dead
Hello all. I have a friend with a recently purchased 2012 390BH. The inverter/charger appears to be working fine (green light and fan running at the inverter), but his remote inside the coach is completely dead. I verified it is plugged into the inverter, did not see any fuse associated with it in the forward compartment and could not find anything in the manual to help me. Any other ideas? Thanks in advance. -Glenn
Glenn and Darcy
2013 Berkshire 390RB
2013 Jeep Wrangler (toad)
Pacific Northwest
Subsailor is offline   Reply With Quote
Old 05-24-2016, 10:51 AM   #2
tmmar's Avatar
No other ideas but why don't you give magnum a call? They can probably help with this.
Tom and Margaret
2014 Berkshire 390bh-60
Old 05-24-2016, 11:28 AM   #3
Go Seahawks!
Subsailor's Avatar
Thanks Tom, that is the next step he is pursuing I was just checking here to see if someone else might have had the same issue in the past. -Glenn
Glenn and Darcy
Pacific Northwest
Old 05-24-2016, 01:40 PM   #4
ceedog's Avatar
Take a close look at the top of the inverter. If you see a red indicator (not lit up, you'll need a flashlight), the inverter's breaker has tripped.
It ain't easy being me...I've tried.
ceedog is offline   Reply With Quote
Old 05-24-2016, 01:57 PM   #5
Go Seahawks!
Subsailor's Avatar
Thanks Ceedog, is that "red indicator" near (or on) the two mini breakers or near the green light that is closer to the center of the coach?
Glenn and Darcy
Pacific Northwest
Old 05-24-2016, 07:03 PM   #6
ceedog's Avatar
The indicator will be on top of the inverter towards the right front corner.
Old 05-25-2016, 03:36 PM   #7
NewEncounter's Avatar
As I recall my remote went dead when I inadvertantly disconnected it. The inverter was still working fine, but there was nothing to be done for the remote. Ordered a new one, plugged it in and that was it.
André Lizotte
Coachmen 37TZ 2014
flat towing 2014 Honda CR-V AWD
NewEncounter is offline   Reply With Quote
Old 05-25-2016, 03:57 PM   #8
Go Seahawks!
Subsailor's Avatar
Thanks Andre. I did verify that his current remote was plugged in at the inverter, but I did not take it out of the wall to see if maybe something was disconnected behind it. -Glenn
Glenn and Darcy
Pacific Northwest
inverter
