Old 10-30-2011, 04:32 PM   #1
ernest917's Avatar
Main drain for fresh water
Where is drain for main fresh water tank on my 08????
ernest917 is offline   Reply With Quote
Old 10-30-2011, 05:00 PM   #2
RnR
On my 2011 it is located on the entrance side. Access is through the door in front of the rear wheel.
Ron & Rhonda
Blessed Above Measure.
Three Terrific Children, Four Wonderful Grandchildren.
All the ways of a man are clean in his own eyes; but the LORD weigheth the spirits. Pro 16:2
2011 Berkshire 390BH DP
RnR is offline   Reply With Quote
Old 10-30-2011, 05:59 PM   #3
ernest917's Avatar
My water control center is on driver's side and I don't remember a drain there..... Nothing on entry side... On my previous Lexington it was under the bed....
Old 10-30-2011, 06:52 PM   #4
Lottery Non-Winner
Ovair's Avatar
The drain for my fresh water tank is on the passenger side, underneath, behind the rear wheels. Has nothing to do with the water control center on mine. I have a couple tubes hanging down and each has a cap on it. When I remove the one that is painted white, my fresh tank drains. When I remove the blue cap, my cold water lines drain (low point). When I remove the red cap, my hot water lines drain (low point).
Your mileage may vary.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Ovair is offline   Reply With Quote
Old 10-30-2011, 10:26 PM   #5
RnR
On my 2011 Berkshire the water control center is on the driver side which is where the low point drain valves are, but the fresh water tank drain valve is located directly across on the passenger side. The water pump is also located there. The door is released by two latches at the bottom of the door not visible until you look under the coach, it doesn't have a handle like the water control center does. Hope this helps.
Ron
Ron & Rhonda
Old 10-30-2011, 10:31 PM   #6
ernest917's Avatar
Thanks.... I'll check it our..... Need to know how to drain everything if it gets really cold....
Old 10-31-2011, 01:51 PM   #7
2011 Berkshire 390bh
wnytaxman's Avatar
I hope your realize that if you are looking at temps into the 20's, you need to fully winterize the coach, not just drain the fresh water tank. Just checking to make sure you don't make a very big and expensive mistake.
wnytaxman is offline   Reply With Quote
Old 10-31-2011, 02:10 PM   #8
ernest917's Avatar
We dont really have temps that low.... Maybe low 30's.....
Old 10-31-2011, 02:19 PM   #9
bend302's Avatar
Famous last words...
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 10-31-2011, 02:23 PM   #10
wnytaxman's Avatar
If you don't drop below the mid-30's, you don't really need to drain your tank for fear of freezing. We drain our tank after every trip to keep the bacteria growth down. You may want to refer to the "Research" thread here in the Berkshire section regarding the heated areas of the tanks. That may also be helpful.
