Old 12-04-2015, 10:48 PM   #21
Kenny kustom's Avatar
Ctek polar.
Under a hundred bucks and is a proper maintainer.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 12-05-2015, 12:04 AM   #22
gasman94's Avatar
Originally Posted by KennyGolub View Post
I just put the 12v tender across both chassis batteries.
I wasn't sure if I would be overloading the charger, so I just got one for each.
Rich
gasman94 is offline   Reply With Quote
Old 12-05-2015, 08:59 AM   #23
KennyGolub's Avatar
Rich
Probably much wiser.
I do turn the master switch off for the chassis batteries, so I'm hoping there won't be too much of a drain on them and work the tender too hard.
Ken
Ken & Laurie
2015 Tiffin Allegro Bus 45LP
2018 Jeep Wrangler Unlimited
Home is Where we park it
KennyGolub is offline   Reply With Quote
Old 12-05-2015, 01:58 PM   #24
gasman94's Avatar
I always have both master switches shut off. Had some issues with parasitic drainage when I left them on.
Rich
Old 12-07-2015, 12:29 PM   #25
Originally Posted by Mmnsc View Post
Kenny
This is the wiring diagram for my 2012 Berk 390-60 BH. I hope it helps.
These wiring diagrams are on the inside of each of the bay doors above the batteries and Magnum inverter on my Berkshire 34QS.
It took a long time before I noticed them, and they are hard to read, so I took a picture of mine.
Gordon Sick, Calgary
2015 Berkshire 34QS
2005 Acura EL (aka Honda Civic)
gordonsick is offline   Reply With Quote
Old 12-07-2015, 12:48 PM   #26
I've been fiddling around with charging procedures, since I don't have shore power where I store my RV. I'm now on a regimen of visiting my RV every 3 weeks to check the voltages of all batteries. I run the generator and turn on the Magnum charger panel inside to watch the charge setup. The chassis battery switch is on, and the house battery switch is on to run the generator.
On my last visit, for one hour, the charger delivered a 100 amp bulk charge. Then it dropped to absorb charging. I went for an errand and came back 3 hours later and it was on float.
Both sets of batteries were charging (they were reading a voltage from the charger and not an internal voltage). Indeed, I had a smart charger (which does bulk, absorb and float) connected to the chassis batteries while I did this -- I plugged it into the 110v port in the middle electrical bay that is designed for the engine block heater. The smart charger read a voltage, but no amps. I believe that is because the smart charger was seeing too high a voltage on the chassis batteries from the charging process from the generator -- I've checked the smart charger and it does charge batteries when there is no other charger hooked up.
This leads me to confident that the generator was charging both sets of batteries.
It is reasonable to expect the same to happen when on shore power.
2015 Berkshire 34QS
battery
