Old 05-25-2018, 08:09 AM   #1
manually crank Berkshire 390BH slide
We have a 2008 Berkshire 390BH. The inverter has a "bridge fault" - which were not sure what that means. We did reset the inverter but still has the fault. Now the generator won't crank. We need to take to repair shop but the sofa slide out is extended and we do not know how to manually get it back in. Any help would be appreciated!!!
pigletat100acres is offline   Reply With Quote
Old 05-25-2018, 08:21 AM   #2
cavie's Avatar
Gen start and Slide are 12 volt. Is Battery switch on? If so shore power and battery should provide 12 volt to slide.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Electric Contractor.
cavie is online now   Reply With Quote
Old 05-25-2018, 08:59 AM   #3
tmmar's Avatar
Turned turned off the house batteries switch and the magnum inverter still showing that it has power. What else needs to be shutoff to shut the power down and remove the house batteries from the circuit?
Tom and Margaret
2014 Berkshire 390bh-60
Old 05-25-2018, 12:40 PM   #4
Berkshire 390QS
NO3putt's Avatar
ID:	173317 There should be a on/off button on the inverter it self, also remove shore power. Skip
Old 05-25-2018, 02:01 PM   #5
tmmar's Avatar
Moderator,
Can you please move posts 3 and 4 from this thread to 'Rust in battery compartment' thread? I was in a hurry this morning and posted my response to the wrong thread.
Thank you.
Tom and Margaret
390bh, berkshire, manual, slide
