Old 06-27-2012, 08:45 PM   #1
Map Light
Ok the ultimate stupid question. How do you use the map lights the ones on the flexable mount. The do not work with the engine on or off. The bulb is good and I can't find a switch that makes it work. The knob on the too does nothing.
Old 06-27-2012, 09:01 PM   #2
2011 Berkshire 390BH
Superchief's Avatar
Next to the headlight switch there is a "roller" type bar. This needs to be moved to the second position, max. Then the map lights will work.
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
Old 06-27-2012, 09:44 PM   #3
Thanks Superchief that works and I have been trying to figure it out since we got the MH on in May.
Old 06-28-2012, 04:46 PM   #4
kingwood390bh's Avatar
Then turn the rear of the lamp housing.
kingwood390bh is offline   Reply With Quote
Old 06-28-2012, 07:15 PM   #5
That I got thanks. It doesn't seem very bright.
Old 06-29-2012, 06:00 PM   #6
Superchief's Avatar
It's not.
Craig
