Old 04-04-2013, 09:17 PM   #1
JBoyer's Avatar
Map Light Bulb - How to get to it?
So while looking at a pre-departure checklist last night, my drivers side map light burned out. Does anyone know how to get into the unit to replace the bulb? My "trifocals" and I have studied this light for 30 minutes and I see no "obvious" way to get the lens out. As always - thanks - travel safe!
2015 Landmark Newport
2015 Silverado 3500hd dually tow vehicle
previous rig
2008 Berkshire pusher
2010 Mini Cooper Convertible toad
2015 Nissan Frontier toad
JBoyer is offline   Reply With Quote
Old 04-05-2013, 10:13 AM   #2
kingwood390bh's Avatar
If you have the same mechanism as I do, the back of the lamp twists and has three positions: on, off, open. Twist past "off" and the back can be pulled off giving you access to the lamp.
kingwood390bh is offline   Reply With Quote
Old 04-05-2013, 10:18 AM   #3
Yours may not be the same, but on my map light there is a third position on the control. On, Off and the extra position at the "counterclockwise end" of the control range. It's a little "stiffer" to turn to that position.
When you do that the knob comes right off and you remove a single screw and the bulb comes right out.
HTH
Boowho??
EDIT: Oops, kingwood beat me to it, sorry!!
boowho is offline   Reply With Quote
Old 04-05-2013, 01:45 PM   #4
JBoyer's Avatar
Thanks to you both = I'll check tonight.
previous rig
