Old 10-13-2014, 09:35 AM   #1
Marker Lights Out
Having an issue with my marker lights, clearance lights and tail lights not working. My headlights work and the break lights are fine. I went to Freightliner over the weekend and picked up a new relay but they did not have the "special" freightliner 30amp fuse needed. Replaced the relay and borrowed a similar 30amp fuse to problem shoot. Nothing has worked yet. I'm working on the top black fuse panel in the front drivers cargo bay. My RV is a 2014 390bh. Any other ideas r suggestions would be greatly appreciated before I bring it into the dealership. As a side note, I never thought it would be so hard to pick up some simple fuses
CT Camper is offline   Reply With Quote
Old 10-13-2014, 02:20 PM   #2
edgewant's Avatar
I had issues with my dash fan. It was intermittent. Turned out to be a bad splice. I located it under the removal portion of the dash. Could be a similar issue you're having.
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
light
