Old 09-28-2015, 07:51 PM   #1
edgewant's Avatar
Marvel Mystery Oil for Hydraulics
Anyone other than Boowho used Marvel Mystery Oil in their hydraulic system to get rid of the popping/clicking the leveling jacks make over time?
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 09-28-2015, 08:52 PM   #2
silver's Avatar
I asked Jamie from equalizer about that while at Goshen. He said that it would not hurt anything if that helps.
silver is offline   Reply With Quote
Old 09-28-2015, 09:06 PM   #3
accumack's Avatar
I put it in mine but have used the Berk since.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 09-28-2015, 09:24 PM   #4
They added it to mine at the rally and it has mad no difference. I get the annoying pop all the time. It doesn't seem to make the MH unlevel but is annoying. I realized I don't notice it when parked on grass. I plan to make some wood pads to put order the jack pads and will put a rubber mat on them. I believe this will be the end of the popping.
Old 09-28-2015, 11:15 PM   #5
edgewant's Avatar
Thanks to all for the replies. I added the $30/qt CAT additive and mine is still popping. I also think it is related to parking on soft surfaces. I carry a set of wooden pads to place under the landing gear and it seems to help.
edgewant
Old 09-29-2015, 07:39 AM   #6
I-RV's Avatar
Besides jack popping, there is the jack punch-through problem which many have had and is where the piston punches through the leveling pad.
I am wondering if the popping and punch-through are not related. I noticed that when I use wooden pads, there is a bolt-nut impression on the wood. I generally do not get the popping with the wood pads, but if my jack pads are on gravel or dirt, I get popping. Wondering if the bottom of the jack piston isn't nibbling at the pad.
One thing that I am convinced of is to always keep the jack pads parallel with the frame and not the ground. I feel that pads that are angled my be more prone to punch-through. - Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 09-29-2015, 07:59 AM   #7
edgewant's Avatar
That sounds plausible.
My theory is that when parked on soft surfaces the weight of the coach over time pushes one or more jacks further into the surface. This unloads one or more of the other jacks and when weight shifts in the motorhome the rod on those unloaded jacks is moving creating the popping noises.
If I manually lower a pair of jacks or auto relevel the popping stops for a period of time or completely in some instances.
edgewant
Old 09-29-2015, 01:24 PM   #8
My Grandfather used it on everything. Hell he liked so much he may have even drank the stuff.
Paul
Paulie Boy is offline   Reply With Quote
Old 09-29-2015, 01:59 PM   #9
Waste of time. My opinion
Harkerr is offline   Reply With Quote
Old 10-03-2015, 12:39 PM   #10
COMPLETELY eliminated our (boowho??) popping sounds.
Boowho??
kaymfischer is offline   Reply With Quote
Old 10-03-2015, 03:42 PM   #11
If it increases the viscosity of the HF and it works how is it a waste of time. You could always just rebuild everything but if a little fairly cheap oil fixes the issue I say give it a try. It helped mine but failed to get rid of all of it. In fact it was suggested and put in my the service tech at the Goshen rally.
Old 10-04-2015, 09:46 AM   #12
jmgllt's Avatar
Good info!
jmgllt is offline   Reply With Quote
hydraulic
