Old 09-18-2014, 09:23 PM   #1
Master power switch
Just serviced my coach batteries, 4 / 6 volt batteries, thought I would do it my self after I had them serviced at Camping world last Aug and the tech didn't secure the acid caps and the battery compartment was now corroding badly. Shut off the master power switch, removed and cleaned the batteries and slide out compartment. replaced the batteries and now my coach will not power up. Pushing and holding down the master switch the power light comes on and I can hear the coach power up but when I let up on the switch the light goes out and no power to the coach? Checked the breaker box and all is fine, any ideas?
Pepi
Pepi La Pue is offline   Reply With Quote
Old 09-18-2014, 10:57 PM   #2
I changed out all of my batteries at the start of the summer. Before removing cables and batteries I made sure to take detailed photos of all connection. I also used white hockey tape to join the ends of all adjoining cables.
I was more than a little scared of a possible arc when making the final connection. As luck would have it ... everything went much easier than expected.
I am sorry to hear of your problems. My only suggestion would be to double check all of your connection. Ensure that all polarities are correct and all connections are secure.
This may be a silly question but have you made sure that all three battery disconnect in battery compartment as well as the one inside the entry door are all set to the on position.
Tim
lefaivre is offline   Reply With Quote
Old 09-19-2014, 07:14 AM   #3
Thanks Tim
No pictures, damn it! knew I should, smart phone in the house charging. Didn't know there were 3 disconnects, will look for more, are they easy to locate?
Thanks again
Pepi
Old 09-19-2014, 08:46 AM   #4
I can send you picture of the battery connections if you like.
As far as battery disconnects are concerned ... they are in the following places.
The one by the entry door ... I never use thus one since it is too far from the batteries and has too many phantom draws.
The three large red knows on the left hand wall of the battery compartment. A since one up top for the chassis batteries and two down below for the coach batteries..
Tim
Old 09-19-2014, 09:17 AM   #5
2011 Berkshire 390BH
Superchief's Avatar
Pepi,
I see you have a 2013 390BH. I have a 2011 390BH. Not sure if battery wiring is the same, but here are several pictures of mine from different angels. I noticed when I changed my batteries recently, that the positive wires have red tape on the ends and the negatives do not. Also in my pictures ignore the white wire and the small red and black wire (toad battery connection). Hope this helps! CraigClick image for larger version
Name:	ImageUploadedByForest River Forums1411136032.391283.jpg
ID:	63060Click image for larger version
Name:	ImageUploadedByForest River Forums1411136077.674492.jpg
ID:	63061Click image for larger version
Name:	ImageUploadedByForest River Forums1411136120.614793.jpg
ID:	63062Click image for larger version
Name:	ImageUploadedByForest River Forums1411136161.106421.jpg
ID:	63063Click image for larger version
Name:	ImageUploadedByForest River Forums1411136195.798674.jpg
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
Old 09-19-2014, 01:57 PM   #6
Thanks Tim and Craig
I see from the photos that I had the two inside batteries turned the wrong way. The coach Powered right up and stayed on. Thank God I didn't blow it up. That was quite helpful and timely as well as I was getting geared up leave this afternoon for a quick golf weekend on the coast. Was just about ready to cancel my Tee times. You made my day,
Thanks again Guys.
Pepi
Old 09-19-2014, 03:07 PM   #7
Glad things worked out for you. Lucky you did not get hurt or do damage to your unit.
In order to get the best life out of your batteries. Ensure that water level remains at full mark. If you need to fill use distilled water. Before storing charge completely and use the 3 battery disconnect switches I mentioned earlier.
Enjoy your holiday
Tim
Old 09-19-2014, 05:52 PM   #8
Superchief's Avatar
Pepi,
You are welcome! As every golfer knows, including me, golf is first and foremost and everything else is second! Glad we could keep your tee time!! Hope you hit them straight and all putts went in!! Craig
Craig
Old 09-20-2014, 12:48 AM   #9
ernest917's Avatar
GOLF???? What's that??? Cow Pasture Pool ???? BASS FISHING RULES !!!!
ernest917 is offline   Reply With Quote
Old 09-20-2014, 02:13 AM   #10
Superchief's Avatar
Ernest, Don't you know that you can fish with golf clubs? But you can't play golf with a fishing pole! Craig.
Craig
Old 09-20-2014, 01:21 PM   #11
ernest917's Avatar
Well I'll admit - when I play golf I do spend a lot of time in the water ....
Old 09-20-2014, 07:05 PM   #12
Superchief's Avatar
Ernest, (lol)!!!! You got to start carrying a fishing pole in that bag!
Craig
Old 09-20-2014, 08:45 PM   #13
ernest917's Avatar
Been there; done that... And yes, it will get you tossed off the golf course.....
Old 09-21-2014, 03:24 PM   #14
Live to Travel!
MightyOaks's Avatar
Just a note of warning that even with all shutoff switches thrown to off, the coach still has a small parasitic draw. In cold climates, even with full charge before disconnecting, the batteries will discharge, freeze and burst. I would recommend keeping plugged in or disconnecting and either placing on a separate trickle charger or store in a location that doesn't freeze.
MightyOaks is offline   Reply With Quote
Old 10-01-2014, 10:27 AM   #15
Terrilegacy's Avatar
I am have corrosion problems on the forward set of batteries on my 2014 Berk RB it is all over the tie down strap. Anybody else seeing this?
Terrilegacy is offline   Reply With Quote
Old 10-01-2014, 11:06 AM   #16
Berkshire 390QS
NO3putt's Avatar
Had the same issue, put the flow rite battery watering system on and haven't had a problem since, also much easyier to water.
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
Old 10-01-2014, 12:02 PM   #17
silver's Avatar
Same Problem Solved
Had this same problem with my 2008 Berkshire. Had to referb the battery bay every year it was so bad and lost the original hold down straps after the second year. Finally replaced the factory batteries and problem left with them. I do not know why the factory batteries acted as they did as they tested good with load tester and would take charge but the out gassing while charging was all full. I had even added vents to the battery bay but it did no good. Got new batteries from Sams Club.
silver is offline   Reply With Quote
Old 10-01-2014, 03:37 PM   #18
tmmar's Avatar
Clean up the corrosion with some baking soda and water. After everything is cleaned up, get some Battery mats. They work very well and will absorb the gases that cause the corrosion. I put some mats on top of the batteries and on the sides.
Acid Neutralizing Mat - Yellow: BatteryMart.com
Tom and Margaret
2014 Berkshire 390bh-60
Old 10-01-2014, 03:59 PM   #19
Once all of your connections are clean and in place you might look into applying a battery terminal protector spray. It seals the connections and is really good at preventing corrosion.
rana is offline   Reply With Quote
power
