Old 03-29-2015, 03:39 PM   #11
tmmar's Avatar
The one Dan posted the link for is the one I have and it works very well!
Tom and Margaret
2014 Berkshire 390bh-60
Old 03-29-2015, 04:08 PM   #12
Ret E-9 Anchor-clanker
donanddona's Avatar
Had an RV park once tell me that their pressure was very high. I installed my regulator but the pressure was poor. Suffered through the first couple of days. After talking and overhearing them say " I have to pay for water in the park and water out of the park, so no leaks." Later I wondered if their pressure was that high or if their water bill was that high. Took off the regulator and the pressure (48psi) was just fine.
donanddona is offline   Reply With Quote
Old 03-29-2015, 06:18 PM   #13
lgray's Avatar
Originally Posted by dan-nickie View Post
Perhaps a little better than a straight line regulator water restrictor, but not much. I looked at the Valterra A01-1117VP. Good for occasional use but is prone to clogs. Biggest issue is flow rate. You will not find a manufacturers flow rate or GPM, from Valterra....wonder why?
If not creating my own, I would go to the website previously mentioned:
http://www.rvwaterfilterstore.com/Pr...Regulators.htm
Their Watts Brass New Model 263A-LF Lead Free Adjustable Regulator, 10-65 range, 4-4.5 GPM. If this Watts is only getting 4 to 4.5 GPM, you can just imagine how poorly the Valterra performs.
lgray is offline   Reply With Quote
Old 03-29-2015, 06:22 PM   #14
Engineer of Crazy Train
ChooChooMan74's Avatar
I have a non adjustable high flow rated at 55-60 psi. Works Great.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 03-29-2015, 06:33 PM   #15
I have an adjustable Watts and am seriously considering the Valterra A01-1122VP that hooks to the cg hose bib.
Old 03-29-2015, 06:44 PM   #16
mcnabbwr's Avatar
I'm not saying they are all bad, however I had two Valterra regulators and both had poor brass castings. One leaked through the porous casting more like a weeping and the other separated where the female hose bib attached. My third one was a Watts and I haven't had a issue.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 03-29-2015, 07:02 PM   #17
Wow - 110 psi seems high. I always install a 60 psi regulator - don't trust campground pressures. If you are used to 110 psi pressure I can understand why installing a regulator with a much lower pressure limit results in decreased pressure within the RV.
You may want to take a look at the owner's manual to determine what maximum pressure is recommended.
2010 Surveyor 294
2006 Ford E-350 Van 5.4
surv294 is offline   Reply With Quote
Old 03-29-2015, 07:05 PM   #18
StoneyG's Avatar
Originally Posted by Campin Cajun View Post
Boowho, check these regulators out. You can see how the GPM rates are different on some models.
RV Water Filter Store: Standard Filter Canisters for Whole RV
Thanks for that. They have a new Fairview Hi-flow regulator that I just ordered for $24.95.
StoneyG is offline   Reply With Quote
Old 03-29-2015, 07:08 PM   #19
bubbles's Avatar
I use the Watts that is pre calibrated (no gage) and fixed at 50psi. I also use a 5/8 hose to maintain as much volume as I can. Out performs any Valterra I ever had.
Old 04-01-2015, 05:51 PM   #20
RKC02's Avatar
I read the installation manual for the Gerard tankless heater and it stated that the heater requires 2.5 gallons per minute in order to work properly. Important consideration when choosing a regulator and/or filters. I use the Watts 263A and it works like a charm. (Now thinking the Doulton ceramic candle filter would make a great addition - high-flow rate and cleanable for long life)
RKC02
2014 390RB-60 "The Shire"
RKC02 is offline   Reply With Quote
pressure, water
