Old 08-13-2015, 04:36 PM   #31
StoneyG's Avatar
Originally Posted by AdamC View Post
Hey Stoney. I was looking at this model as well. Did you happen to go through with the Fairview and what do you think of it?
- Adam
I did buy it but haven't yet used it maybe because I haven't had any water pressure issues lately. When I do have issues I'll check to see if it works.
StoneyG is offline   Reply With Quote
Old 08-13-2015, 06:38 PM   #32
tnbendr's Avatar
Originally Posted by dan-nickie View Post
Do you just use that at the spigot Dan, or did you plumb it into your control panel?
Ben & Michelle
2015 Berkshire 38A
2005 Jeep Wrangler toad
tnbendr is offline   Reply With Quote
Old 08-13-2015, 07:30 PM   #33
I-RV's Avatar
Dan, that looks like a great find. It states that it is factory set to 45 psi. Can the output pressure be changed?
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 08-13-2015, 07:58 PM   #34
X2 in the Valterra gauge.
Paul
Paulie Boy is offline   Reply With Quote
Old 08-13-2015, 08:10 PM   #35
dan-nickie's Avatar
I do put it at the spigot, but maybe I should look at putting it in the water bay as I am prone to forget it sometimes.
Dan
2014 Berkshire 390RB-60
dan-nickie is online now   Reply With Quote
Old 08-13-2015, 08:12 PM   #36
dan-nickie's Avatar
Hank
Yes it is adjustable. I have mine set around 50 psi. I think Phil says that 55 psi works best for his Gerard heater.
Matter of fact, I recall we got it to help stabilize the hot water temperature.
Dan
Old 08-13-2015, 10:26 PM   #37
Witch Doctor's Avatar
Originally Posted by boowho View Post
What is safe and reasonable for water from a park? I've seldom used a regulator although I've had one for a long time.
Yesterday I checked into a park and was warned at check in that their pressure is 110 lbs. I hooked up my trusty regulator for the first time in a year or so and it was set to 50 lbs.
It seems to me that is not enough pressure at the inside fixtures. Can I go higher without blowing the whole plumbing system apart?? If so, how much??
Boowho??
When I was in Goshen mine was set at 60 PSI no problems, when you hear like a whistle when you open a facet to much pressure...
Coachmen M/H
Concord
2018 / 300 DSC
pressure, water
