04-01-2015, 05:15 PM
#21
I take it none of you that (Must have 50+WP) ever DRY Camp! Our unit works just fine with the Factory installed water Pump,and you know they put out (NO where near 50+PSI and very LOW GPM)! Now we do have a 5gal pressure tank but PSI is still way Under 40PSI! We have our City water Reg. set at 40PSI and see NO diff from our pump! Youroo!!
04-02-2015, 07:03 AM
#22
“Apples and Kangaroo’s” comparison, between dry camping and city hookup.
04-02-2015, 07:20 AM
#23
When a person turns on a water item in a RV they should receive the Same output (City or Pump)! If they need (60+PSI) to achieve this output they have Issues! I was replying to the Posts that said they needed High PSI. Youroo!!
04-02-2015, 07:25 AM
#24
Pressure regulator
I have been using a adjustable pressure regulator ever since encountering
water pressure of 115PSI at a KOA campground in Forsyth, GA. The pressure was so great, it was blowing the fresh water hose out of the fitting
connection on the side of the RV. I set the adjustable regulator @ 50 PSI
max. Works great.
The only problem is the hand on the meter is not pressed on tight enough, had to replace the meter with a better meter.
Valterra A01-1117VP Brass Lead-Free Adjustable Water Regulator.
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
04-02-2015, 07:33 AM
#25
That is incorrect.
04-02-2015, 07:45 AM
#26
That is incorrect.
Not in our units water system,sorry if others have issues! Just trying to Help,your choice! Youroo!!
04-02-2015, 08:09 AM
#27
Originally Posted by StoneyG
Thanks for that. They have a new Fairview Hi-flow regulator that I just ordered for $24.95.
I'm curious as to how well that one works. Let us know after you try it out please. Jerry
2005 GMC Sierra 2500HD, Duramax CC/SB
2022 Rockwood 2613 BS
08-13-2015, 07:35 AM
#28
Fairview Hi-flow
Hey Stoney. I was looking at this model as well. Did you happen to go through with the Fairview and what do you think of it?
- Adam
08-13-2015, 08:26 AM
#29
It has been years since the lead was taken out of plumbing solder since lead is carcinogenic. However, just recently I was buying a brass plumbing fitting (on Amazon), was warned it was not not lead free and not to be used for potable water.
In reading this thread, I thought about updating my water regulator to a Watts H560G. Yes, it is sold somewhere, but it has been discontinued and replaced by the FFH560G (Lead-Free model).
I thought the FR forum should be aware of this.
Hank
Gale & Hank- 2012 Berkshire 390BH
08-13-2015, 11:04 AM
#30
Don't know what the MAX pressure would be, but on my ShureFlo the pressure coming out of the pump is adjustable via a set screw. However, increasing the pressure will not help much unless the pump has a fairly high GPM rating, which mine does not.
Boowho??
08-13-2015, 03:36 PM
#31
- Adam
I did buy it but haven't yet used it maybe because I haven't had any water pressure issues lately. When I do have issues I'll check to see if it works.
08-13-2015, 05:38 PM
#32
Originally Posted by dan-nickie
Do you just use that at the spigot Dan, or did you plumb it into your control panel?
Ben & Michelle
2015 Berkshire 38A
2005 Jeep Wrangler toad
08-13-2015, 06:30 PM
#33
Dan, that looks like a great find. It states that it is factory set to 45 psi. Can the output pressure be changed?
Hank
08-13-2015, 06:58 PM
#34
X2 in the Valterra gauge.
Paul
08-13-2015, 07:10 PM
#35
I do put it at the spigot, but maybe I should look at putting it in the water bay as I am prone to forget it sometimes.
Dan
2014 Berkshire 390RB-60
08-13-2015, 07:12 PM
#36
Hank
Yes it is adjustable. I have mine set around 50 psi. I think Phil says that 55 psi works best for his Gerard heater.
Matter of fact, I recall we got it to help stabilize the hot water temperature.
Dan
08-13-2015, 09:26 PM
#37
Originally Posted by boowho
What is safe and reasonable for water from a park? I've seldom used a regulator although I've had one for a long time.
Yesterday I checked into a park and was warned at check in that their pressure is 110 lbs. I hooked up my trusty regulator for the first time in a year or so and it was set to 50 lbs.
It seems to me that is not enough pressure at the inside fixtures. Can I go higher without blowing the whole plumbing system apart?? If so, how much??
Boowho??
When I was in Goshen mine was set at 60 PSI no problems, when you hear like a whistle when you open a facet to much pressure...
Coachmen M/H
Concord
2018 / 300 DSC
