06-01-2018, 06:49 AM
Metal Filings (Aluminum) Near Corner of Schwintek Slide
Have noticed metal filings (aluminum) on the bedroom carpet. Located near the rearmost corner of the wardrobe slide, under the corner of the slide (when slide is in). Has anyone noticed the same or know the cause and/or necessary repair? Am concerned.
2017 Berkshire XL 40A & 2017 Ford Focus SE
I Built and Fly - Van's Aircraft RV-12
Ham Radio - W9EAA
06-01-2018, 08:16 AM
I would vacuum them up and see if it happens again before I tore anything apart. It could just be remnants from the build. Most people have found sawdust and/or metal shavings that weren’t cleaned up after construction.
Bruce
06-01-2018, 08:23 AM
X2
06-01-2018, 11:10 AM
Bruce
Vacuumed twice and has recurred.
Ham Radio - W9EAA
06-01-2018, 11:27 AM
Have you tried the slide lubricant?
2006 F-250 CCSB 4x4 6.0 Powerstroke
Air Lift 5k bags w/ onboard compressor
2022 Keystone Raptor 351
B&W Companion
06-01-2018, 11:33 AM
Do you see any physical damage to the slide rails/gears?
06-01-2018, 12:00 PM
Yes this! Youroo!!
06-01-2018, 01:46 PM
What causes that?
Bruce
06-04-2018, 08:59 PM
Slide Tracks Look Perfect - No Wear Pattern
I took a hard look at the four slide tracks. None of the tracks show any sign of wear. BUT, it appears each time I move the slide out and then in, I end up with more metal filings on the carpet. Anyone have an idea what could be wearing abnormally??
06-05-2018, 06:55 AM
Do you have the aluminum plates installed on the underside of the slide? If so, possibly coming from them
06-05-2018, 07:08 AM
No. Have NOT installed the plates. The metal filings are under the inside most aft corner of the slide on the bedroom carpet when the slide is fully in.
Ham Radio - W9EAA
06-05-2018, 07:12 AM
The cause is Construction debris. The carpet is installed first then the rest of the rig. I'm surprised the carpet makes it to the end. The repair is a vacuum cleaner.
06-05-2018, 07:54 AM
Have vacuumed several times, the metal filings reappear.
06-07-2018, 11:10 AM
Mine too
Might be the edge of the motor shaft rubbing against the gear. Mine was doing same thing. I held up bed and brought slide in and out, and both the gear teeth as well as the teeth on the gear rail on the bed had no signs of visible wear. The motor shaft (non-toothed section) was right up against the teeth of the bed, so that was the source of my metal shavings.
I will keep checking, but I think that it will eventually stop once the gears have "found their way".
2018 FR Berkshire XL 40 C
2019 Jeep Wrangler
