Old 06-09-2016, 06:06 AM   #1
mikeborny's Avatar
Microwave loose.
My microwave is loose and squeaks while driving. I looked to access the bolts to tighten but can not seem to access them.
Mike & Amy + 3 and the dogs!
2014 berkshire 390bh-40
mikeborny is offline   Reply With Quote
Old 06-09-2016, 07:09 AM   #2
15berkxl's Avatar
Mike doesn't yours have bolts or screws in cabinet or access panel above microwave? Caution two person job.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 06-09-2016, 07:33 AM   #3
Go Seahawks!
Subsailor's Avatar
Hey Mike, not sure about yours, but a lot over the counter microwaves/convection ovens have a slide in mount that is mounted first (normally through a cabinet floor above) and then the oven itself slides and "locks" into the mount. If the bolts are tight above (assuming you can find/see them) the slide in mount itself may be a bit loose. I have made similar fixes with some thin rubber or plastic pieces to shore up the mount. As Wayne says, this is indeed a two person job. These newer ovens are pretty darn heavy and kind of awkward to work with. -Glenn
Glenn and Darcy
2013 Berkshire 390RB
2013 Jeep Wrangler (toad)
Pacific Northwest
Subsailor is offline   Reply With Quote
Old 06-09-2016, 10:40 AM   #4
Mmnsc's Avatar
There is a false bottom to the cabinet above the microwave. You need to pop the thin plywood up , it is just stapled down. There are 2 big screws, one on each side that tend to loosen as you drive. Tighten them up and you should be good to go. The bracket on the back is a drop in that holds the micro to the wall.
On mine, I did not reattach the false floor to the cabinet so I can periodic keep the 2 front screws tight.
If you want to take the micro down, you must remove the 2 screws first, tilt the front down and lift the back off the mounting bracket. It is definitely a 2 person job and maybe a third to remove the screws.
Mmnsc is offline   Reply With Quote
Old 06-09-2016, 10:22 PM   #5
mikeborny's Avatar
Thanks, will tackle that project Saturday. Don't think I can handle that squeaking on a 7000 mile trip.
