Old 01-26-2011, 09:49 PM   #11
RoamingEngineer's Avatar
BTW, are there any Forest River reps on these forums?
RoamingEngineer is offline   Reply With Quote
Old 01-27-2011, 10:05 AM   #12
tmmar's Avatar
Don't know if Forest River is monitoring this site but it seems that the camera problems affect a number of different model year motor homes so I don't think it was just a bad batch of cameras. I think that there is a design flaw that is causing the problems.
Tom and Margaret
2014 Berkshire 390bh-60
Old 01-27-2011, 12:48 PM   #13
Good point on the year. I find it odd that I have one camera that is affected and one that isn't. This happened when we went from Florida to the Shenandoah valley. As soon as we dropped into the freezing temps, my camera developed a haze on it. When I stopped at a campground, I could see water on the lens. We hadn't been in any driving rain or anything. It seems like the moisture is already in the camera and the trip to cold weather just caused it to condense.
Old 01-27-2011, 01:06 PM   #14
tmmar's Avatar
Your description of how the moisture develops is right on. Also, on mine, it will happen when driving in the warm weather after sitting overnight. Very frustrating- not to mention dangerous when you really can't use the camera to see what's coming up the side.
Tom and Margaret
Old 01-27-2011, 07:15 PM   #15
Question to all, is there a removable protective lens on the camera that you notice? I don't know what they look like. I have a hand held camera with multible lens and i have a clear protective lens that screws on the front of it and you can't see it, just wondering if yours has that.
Old 01-28-2011, 07:08 AM   #16
tmmar's Avatar
There is a clear 'lens' in the front of the camera. Don't know if it is removable or not. I'm not sure it would be a good idea to remove it since it could lead to damaging the cameras internals. I found that after travelling for a while, the camera will get a coat of dirt over it that I clean off every time I fuel up so that could intrude into the camera.
Tom and Margaret
Old 01-28-2011, 07:34 AM   #17
Thanks for the info. The reason i was asking is because with high end lenes the clear protective lens is there so it can be removed and clean rather then cleaning the actual camera lens, if the protective lens gets damage it is cheaper to replace, if the actual len to the camera is damaged then there is nothing that can be done about it because it is a fix lens.
I thought that if your cameras had this protective lens and it became loose then moisture and dirt could get between the two.
Old 01-28-2011, 08:45 AM   #18
tmmar's Avatar
The clear cover is not easily removed and the housing holding the cover is tight so I don't know why moisture would get in there since the cameras are supposed to be waterproof.
Tom and Margaret
Old 01-28-2011, 09:05 AM   #19
If they claim to be waterproof then one would think it would have a lifetime warrenty as long as you own it....Sorry you guys are having problems with them, just thought i could try to help.
I installed a back up camera on the back of my pick-up two years ago and so far no problems and by looking at it the lens it looks like it is fix as well. I guess time will tell.
Old 01-28-2011, 09:52 AM   #20
CLASS "A" Senior Member
cfsoistman's Avatar
I bought a set of replacement headlights for my daughter's Mustang. After the first rain I noticed one had fogged up while the other did not. I contacted the vendor I bought them from and he said it was most likely trapped humidity. His recommendation was to remove the bulb and take a blow dryer to help dry up the humidity. I waited until a nice sunny day, removed the headlight and left it in the sun with the bulb openings facing up. After reassembly the headlight has been perfect. Now I know a headlight has openings to vacate the humidity, but I wonder if during the assembly of those side camera assemblies if there could be humidity trapped in there and depending on the change in temperature outside if this is causing the fog up? Just a possibility!!!
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
