Okay here's what I know... icemaker has power, water turned onunder sink in bathroom, lever in down position on icemaker, when I stick screwdriver in a little gears to advance cycle nothing happens, so what am I missing? Is there a fuse for icemaker alone?
Ok been a long time since last ice maker question...when solenoid opens up to let water up to ice maker I notice a bit of water squirts out from were the line disappears behind the fridge on way to ice maker. I guess there must be some problem behind the ice maker itself. I will likely have to let the freezer unthaw and then remove the ice maker from the freezer and see what is going on behind it.
Anyone had the ice maker unbolted from the freezer?
