Old 10-18-2014, 10:12 AM   #21
Originally Posted by KennyGolub View Post
How do you get the antifreeze into the lines? Run the pump with a hose dropped into the AF jug ?
If you are talking about getting AF into the ice maker lines I made a jumper cord out of an cheap extension cord. Any old cord will work. Use the plug end and cut off the other end. I put the proper connectors on the end to connect to the solenoid. With that I can run the AF through the lines and also flush it out in the spring. This is for the Dometic four door fridge.
Old 10-18-2014, 11:02 AM   #22
Berkshire 390QS
NO3putt's Avatar
MH winterized right now, but heading to south texas right after the holidays.
Old 10-18-2014, 12:15 PM   #23
Skip where are you staying? We will be in Mercedes and Riviera.
Old 10-18-2014, 05:10 PM   #24
Berkshire 390QS
NO3putt's Avatar
Phil, we will be staying at Victoria Palms in Donna for Jan anyway, haven't made plans for rest of time. Thought we would look around while we down there for other place.
Old 11-07-2014, 06:20 PM   #25
Approximately how many gallons of antifreeze does it take? Went to camping world over the weekend and they acted like there was a mad rush to get your hands on the pink stuff.
CT Camper is offline   Reply With Quote
Old 11-07-2014, 06:27 PM   #26
It's all relative to how big your water system is, but i'd say 2 gals should do the trick.
Old 11-07-2014, 07:13 PM   #27
RKC02's Avatar
CT: by the time I got pink thru all the faucets, showers, toilets and the washer, on hot and cold sides, I used over 5 gallons. There is a lot if water line in a Berk!
RKC02
2014 390RB-60 "The Shire"
RKC02 is offline   Reply With Quote
Old 11-08-2014, 09:50 AM   #28
tmmar's Avatar
CT-
I too used about 6 gallons of anti-freeze. Also, you should check to see if you have an ACE hardware near you. Not sure if the sale is still on but they had the pink stuff on sale for $2.99 and if you have their rewards card you got $1 off making it $1.99. They had a limit of 2 but I bought 2 and my wife bought 2, we went out and came back into the store and did the same thing.
Good luck,
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 11-08-2014, 10:19 AM   #29
2011 Berkshire 390BH
Superchief's Avatar
CT, Walmart also sells it. The only place I could find it in the South, as most do not use it there.
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
winter, winterize
