Old 06-04-2016, 12:28 PM   #81
CAT-RN's Avatar
Ok. I tried to do a forced regen-- computer WILL NOT allow unless DEF light is on or the system needs it.
Now to disconnect the regen switch is another story!!! Got it disconnected but it is not easy. Just to get under there is a task.
500 mile on mine now since problem. All well.
Russell
CAT-RN is offline   Reply With Quote
Old 06-04-2016, 12:56 PM   #82
ernest917's Avatar
Is regen associated with DEF???? Not familiar with it is....
ernest917 is offline   Reply With Quote
Old 06-04-2016, 01:29 PM   #83
MotoxDad's Avatar
Regen has nothing to do with DEF. They are two completely different systems. Not trying to belittle you at all Ernest.
DEF is used to cut down on exhaust emissions.
Regen is simply when the DPF-(Diesel Particulate Filter) gets full of soot, and requires it to be burned off. It uses diesel gas to heat up the filter to temps upwards of 1500 degrees Fahrenheit so the soot can be burned off to clean the DPF.
Regen is generally done automatically when you are driving at highway speeds, however there are instances where it may require you to do a manual regen if you are not up to highway speed and can't be done automatically.
John
2014 Berkshire 400BH
Motocross Dad
MotoxDad is offline   Reply With Quote
Old 06-04-2016, 02:47 PM   #84
ernest917's Avatar
OK - now I totally understand...... Since I have a 2008 Mercedes turbo in my Berkshire, I have no need to be concerned since I don't require DEF..... Thanks - that's all I needed to know....
