Old 05-30-2016, 09:38 AM   #1
CAT-RN's Avatar
Motor shuts off
I have a 2014 Berkshire. With the 360 motor 3000 transmission
Has been in the barn for 60day. Before going into the barn we drove it home from Florida. No issues.
Today I got it out of barn. Went 6 mile and check engine light come on. Then computer says shut off motor. I had pulled into parking lot and Motor was at idle. It shut down on its own.
All gauges are fine- no high temp, water level about 1" below cap. Oil pressure good. Oil full. No high temps??
I made it back home but computer will shut engine off after running maybe 3 minutes.
No one open today but I do have a friend coming to hook it to scanner to maybe read something.
Anyone had this issue.
Thanks.
Russell
CAT-RN is offline   Reply With Quote
Old 05-30-2016, 09:51 AM   #2
VinceU's Avatar
Thanks.
Russell
DEF system failure?
Old 05-30-2016, 09:52 AM   #3
This issue is normal and is programmed to do so to protect the engine. Shutdown and or debate will occur when following happens
Low coolant, coolant temp too high, oil pressure low, def level low or out, low oil level, low fuel pressure.
Could be as simply as a bad sensor.
Not sure what 360 is, is that gas or diesel
clutchd is offline   Reply With Quote
Old 05-30-2016, 09:52 AM   #4
CAT-RN's Avatar
Good chance that's where it at ??
Russell
Old 05-30-2016, 09:53 AM   #5
CAT-RN's Avatar
360 hp cummins
Russell
Old 05-30-2016, 09:58 AM   #6
Carknocker Family
Ida Ratherbe Camping's Avatar
I vote for low coolant. Work truck does it all the time. Usually less than quart low, looks normal in overflow/surge tank. Put a little antifreeze in it.
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
Ida Ratherbe Camping is offline   Reply With Quote
Old 05-30-2016, 10:00 AM   #7
CAT-RN's Avatar
I'll do that. My mechanic saying same. Thanks
Russell
Old 05-30-2016, 10:13 AM   #8
CAT-RN's Avatar
Maybe it took 1/2 gallon. Check engine & stop lights still on. I wait for computer scanner to get here.
Russell
Old 05-30-2016, 10:18 AM   #9
tmmar's Avatar
Did you try calling the Freightliner Help Line (800-FTL-HELP)? They are supposed to be open 24x7. I would try calling and see what they say.
Tom and Margaret
2014 Berkshire 390bh-60
Old 05-30-2016, 10:20 AM   #10
CAT-RN's Avatar
My mechanic is on the way. But yep I got their #. Will wait on him to get here. Thanks.
Russell
