Old 09-28-2014, 09:53 AM   #1
Motorized sun shade will not come down
Hi, anyone have this issue? I saw some earlier posts on the reset switch, we found them, tried but it did not work. I read some posts about the shade going up or down but only an inch, our will go up but not down at all.
Sylvie is offline   Reply With Quote
Old 09-28-2014, 12:09 PM   #2
Is it the same with engine off and on?
lefaivre is offline   Reply With Quote
Old 09-28-2014, 01:02 PM   #3
Yes!
Old 09-28-2014, 02:03 PM   #4
Have you checked at 12 volt fuses
Old 09-28-2014, 02:05 PM   #5
Yes...both shades night and sun are on the same fuse...the night shade still works...for now anyhow!
Old 09-28-2014, 02:23 PM   #6
Campin Cajun's Avatar
Maybe check the switch, a wire may have come loose. From what you are posting you can rule out the motor and also fuses.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 09-28-2014, 02:50 PM   #7
Sounds to me like either a loose connection or a faulty motor.
Old 09-28-2014, 04:20 PM   #8
Mike checked the switch and the wires for loose connections, the shade makes a small jerk but stops immediately. I guess I will contact Forest River and see what they think? Does anyone know what the make is I don't seem to have any documentation, the only thing I found was a United Shade card, but no specs or anything.
Old 09-28-2014, 09:03 PM   #9
Cyclone
beipers's Avatar
Sounds like they've fallen out of calibration. It can happen for apparent reason. When you reset them you'll need to do both. They are MCD shades. Google it and you'll find their website which had the installation manual which includes the procedure. I keep a copy on my tablet in the motorhome because it had happened 3 times to me.
2015 SOB 5th Wheel
2013 Chevrolet 3500 CC, DD SRW
1 Wife, 2 Kids under 5
Camping nights: 2015 - 19, 2014 - 39, 2013 - 48
beipers is offline   Reply With Quote
Old 09-28-2014, 09:14 PM   #10
Cyclone
beipers's Avatar
Actually, if you've already pressed the switches, you've entered calibration mode. Those are not a reset switch, their actually a programming switch. Here is the website. http://mcdinnovations.com/
Here's a link to the manual. http://www.mcdinnovations.com/files/...-3-website.pdf
2015 SOB 5th Wheel
Old 09-28-2014, 09:24 PM   #11
Ok cool thanks...I will take a look!
