Old 09-27-2016, 07:04 PM   #1
mud daubers
Cranked up my AC units after being in storage over the summer, and the rear unit sounded just awful - like a bearing going bad.
While I was washing the roof, I hosed down the units and saw a bunch of sand running out of the rear AC unit, and knew what the problem was.
Mud daubers in the the fan rotor!
Also discovered a bunch of dead insects, spiders, and really clogged coils which got rinsed from the inside out. So I've added yet one more task to the annual maintenance list...
So if your AC ever sounds really bad, now you know!
John and Heather Crowe
Tomball, Texas
jccrowe is offline   Reply With Quote
Old 09-27-2016, 07:28 PM   #2
Blackhat6mike's Avatar
Send a message via Skype™ to Blackhat6mike
They do love the freshwater vent tube also. I pack mine with a piece of plastic screen wire.
2013 Silverado 2500 HD Duramax/Allison Tuned
Aviator Wright Flyer #1919
"First In, Last Out". 11B4Y
DAV, MOPH, VFW, 5/7 Cav,1/8 Cav Assoc.
11th ABN Pathfinder Co. N7MIP
Blackhat6mike is offline   Reply With Quote
Old 09-28-2016, 01:40 PM   #3
One fine day I was outside and watched mud dobber flying in and out of my engine air filter input, didn't like that so got some magnetic floor vent covers and cut to size to cover the air intake. Now I do also cover my ignition switch with a sign to remind me to remove before starting engine, but now no more nests in the engine intake, scary to me.
Bill
2015 Charleston 430RB
Billr is offline   Reply With Quote
Old 09-28-2016, 01:59 PM   #4
BamaBob's Avatar
They like your furnace vents too - they make screens that cover these vents - you might want to invest in some
Also for our A/C, we took the covers off and lined the vents with screen door mesh and secured it to the inside with Gorilla Tape
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 09-28-2016, 04:46 PM   #5
Oakman's Avatar
We had a mud dauber build a nest on one of the A/C fan blades while our fifth wheel was sitting at the storage lot for a few weeks. It threw the balance of the fan off so badly that when I turned on the A/C the entire fifth wheel started shaking. That was a “what the hell” moment.
The nest was well hidden on the backside of the fan blade so I didn’t find it right away. Once I found it I kept spraying it with water until the nest turned back into mud and scraped it off with my fingernail. Working on the roof in the middle of summer…not fun.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 09-28-2016, 05:22 PM   #6
Had the same thing happen 3 or 4 yrs ago. It was 90° out and I ended up having to take the blade off and cleaning. We were in FL at the time. When I got home, I removed the cover and covered the entire area between the compressor and the condenser with screen wire. NO MO MUD DAUBERS.
Old 09-28-2016, 05:59 PM   #7
M109Rrider's Avatar
Same thing earlier this year. Was checking everything out before leaving on a trip. Ac wouldn't run. Found a nest big enough it wouldn't let the fan run. Luckily the thermal overloads worked and didn't burn the compressor/fan motor up.
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
