I have three considerations for you, AlmondFarmer.
First of all, I did get the screw brackets for the slides. They are great, except there is very little sturdy flange on the slide-out to place the bracket. There a great chance of prying off the slide's flange.
Secondly, my drivers side kitchen slide kept going out and a new hydraulic ram and anti-creep valve fixed the problem.
My third point is that this is the deepest slide with the longest ram. The design underneath is kind of shoddy, since its very difficult to keep the ram from being a pry-bar on the chassis frame. This I feel, wore out the internal seal in the ram. The best way to understand this point is to lay down in the cargo bay and have someone bring the slide in and out while you view what's happening with the ram. There is two possible problems; one the ram's extension rod hitting the slide's timing shaft (running perpendicular). Next is the ram's body moving downward on the chassis frame.
This is why this slide has the most creep-out problems.
Hank
Gale & Hank- 2012 Berkshire 390BH
